Are these mud flaps OEM??
scz4
Post by scz4 » Thu Feb 11, 2016 8:25 pm
Nice car and spec, but those mud flaps look a little OTT! Are the BMW OEM?
If removed, can I assume there would be rub marks behind?
Re: Are these mud flaps OEM??
Post by X5Sport » Thu Feb 11, 2016 9:01 pm
Look it, just painted.  Standard fit just black rubber.  Look good actually.
Post by Horizon » Thu Feb 11, 2016 9:19 pm
+1 I think the painted mud flaps look good, miles better than the black ones.
The E70 with 20" wheels tend to chip the paint on the doors and arches. BMW dealers have sprayed chip protection clear film on them to prevent this. If you remove them make sure the lower doors etc have the film on them.
Nice looking motor
Post by X5Sport » Thu Feb 11, 2016 9:20 pm
There might be marks behind, only one way to find out though.. :(
One note of caution.  I had a couple of the rivets go.  They are only available with the full kit, not as a separate repair item. >:(
celica
Post by celica » Fri Feb 12, 2016 12:30 pm
I have these and non painted
Fitment isn't great on mine from previous owners as there are gaps in the join to bodywork held up previously by I imagine double sided tape, so I can see it had rubbed and marked the bodywork on mine so are staying on for now
Mine have plastic pop rivets in arch holding them into place as well and some are a little loose, so I assume can easily be taken off
I guess having them on saves the paint work and amount of dirt on car
Post by X5Sport » Fri Feb 12, 2016 4:12 pm
It's these plastic pop rivets that dealers can only get as part of a complete kit, not on their own!  I have tried others from the BMW Bodyshop but they don't hold properly.  And yes the correct fitting uses double sided tape as a seal and the pop rivets to hold everything.
Beefcake-2001
Post by Beefcake-2001 » Fri Feb 12, 2016 4:16 pm
you can find the one use rivets on ebay.
Beefcake-2001
Post by Beefcake-2001 » Fri Feb 12, 2016 4:18 pm
Post by X5Sport » Fri Feb 12, 2016 4:22 pm
Those are the ones I tried and the correct ones are slightly different.  Longer and larger diameter, not by much but it's significant it seems.
celica
Post by celica » Fri Feb 12, 2016 6:56 pm
I was getting excited thinking I would try and fix the loose flap then
Could do with double sided tape and pop rivets
scz4
Post by scz4 » Sun Feb 14, 2016 8:36 pm
So test drove the cat today. Mud flaps were all solid. I actually liked the mud flaps in real life, looks quite purposeful. Don't think I'd choose them, but also I wouldn't remove
Post by Horizon » Sun Feb 14, 2016 8:42 pm
[quote="scz4"]
I don't know if I should contact the RSPCA, or get you to check your auto correct before pressing the " Post " button
scz4
Post by scz4 » Sun Feb 14, 2016 8:43 pm
Car! :D
