Check brake lights
andym3
Check brake lights
My check brake lights keeps coming on, but have checked the lights & they are working fine!
Any ideas? :-[
Any ideas? :-[
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
Re: Check brake lights
Intermittent bad connection on the bulb holder most likely. The bulb check test is only a short pulse and may be highlighting a poor connection.
andym3
Take them off & give them a clean then you recon?
storminmike
Agreed.....look at the brake/tail light holder. Have you taken it out, given it a teensy tweak on the holder ears and put it back?
A quick dab with fine wet n dry on the back of the lamp...or worst case take the light out completely and look for pits where the holders make contact. Bit of fine sanding or filling with solder
andym3
[quote="storminmike"]
Ok thanks, I'll hopefully find time over the weekend to sort it out!
storminmike
[quote="andym3"]
Don't drop the nuts!!!!!!!!!
andym3
andym3
Found the problem & now sorted! Thanks for the advice all!
Nice bit of insulation you have there.....
andym3
Yeah not sure why it went like that as the other two bulb holes were fine no rust! Anyway cleaned it up with a wire brush & re positioned the seal & now all good!
- Steamyrotter
That looks about normal for an E53!!
Mine appear to have rusted right through!!
Please note...
Please note...
andym3
Is weird how they rust like that when that part is not open to the elements! :-[
storminmike
Have you been imitating James Bond under water
andym3
How did you know?
Is weird though as the other two bulb holes on the same light are rust free! It was literally the brake light hole! :-[
How did you know?
