3.0sd can you see the radiator through the kidney grills?
Re: 3.0sd can you see the radiator through the kidney grills?
Depends upon whether you have airflow control flaps, and if they are open or closed.
I could on my old 3.0sd. It also had the flappy things
Flappy things?
I can with mine but with others I think I might have seen a grill in picture but hard to tell?
I have active grill shutters on my 35d sport
[quote="rob"]
^ "flappy things"
^ "flappy things"
Not to be mistaken with the other flappy things - swirl flaps!
[quote="rob"]
Could you post a picture please?
How do they open and close, electrical?
Some are electrical, some airflow driven, and some not even fitted.....though the reasons for each version I am not sure of. My X6 has none in that area but I have seen others with! Might be to do with the engine/spec?
Non fitted on my car, its an 08 plate 3.0sd..
I can see the radiator etc right through the grills,
If it had been fitted with flaps, it mightve stopped the a/c rad getting damaged, from stones...
Dave W.
BMW E70 X5 40D
BMW E70 X5 40D
Airflow control flaps fitted to my 2012 4.0d, can't move them by hand so I guess they are electrically operated.
x6 M50d
[quote="Nine468"]
Same year and model without here to
None on mine. Didnt know if it was something to do with the adaptive suspension setup or the 4 zone ac
They are fitted as part of the effecient dynamics according to the information I got with car it apparently warms up quicker and creates a better slip stream when in the closed position
