bmw x5 4,8is e53(inactive selflevel suspension)
I have problems with the air suspension, it works fine uintil the fault popping up, an then its dont work uintil i delete the fault whit a pc.
may it be the alternator?
0
No votes
the compressor?
0
No votes
Total votes: 0
kld1988
Post by kld1988 » Tue Jan 20, 2015 10:58 am
I have this warning lamp, inactive selflevel suspension. i have checked all of the airsprings, no leak, checked the sensors, all working. When i delete the faultcode, it gets back after 3-4 days. it works fine uintil the fault is popping up again. someone knows what it can be? I live in norway, i need to get the car higher som times:P tnx.
Re: bmw x5 4,8is e53(inactive selflevel suspension)
Post by X5Sport » Tue Jan 20, 2015 11:12 am
What state is your battery in?  Well known fault code when the battery is failing/poorly charged.  Lots of posts about this on here.
Oh and :hi:
kld1988
Post by kld1988 » Wed Jan 21, 2015 9:19 am
Oh, i havent checked the battery,  but the ligths inside the car is blaffering.  May be the battery then?  I will check the battery later:) tanks! :)
kld1988
Post by kld1988 » Thu Dec 17, 2015 3:34 pm
HI! Now the ``self Level inactive`` lamp is on,  the tyrepressure lamp, and the green heigthlevel diode is dead.
Someone had this problem?:\ i soon get a mental brakedown!
X5-D-Sport
Post by X5-D-Sport » Tue Dec 22, 2015 2:04 pm
if the battery is low or not in a good condition, then all sorts of warnings will pop up - not necessarily in any predictable order, and appear or vary car by car.
I had transmission warnings pop up when the lights were switched on.....
I've also noticed that the general wiring is "just" capable of the loads imposed on it, and therefor can throw warnings at the slightest load situation.
I replaced my battery with a 1,000 crank Amp cell, and this helped significantly...
Also, the alternator packed up shortly after.... so get these checked at your local motor store...
The battery when engine running should read approx. 13.8 volts +/- 0.3v
and
read approx. 12 volts when engine is not running/charging.
Hope this helps
