E70 LCI Buying Advice
rickz
Hi Guys,
I'm in the market for a BMW X5 E70...I had an initial budget of £20k but I am stretching this to around £22,500 in order to get an LCI...
What other benefits am I getting for going for an LCI? As far as I'm aware...
Better economy, 8 speed gearbox, better lights, newer idrive and better looking exhausts.
Anything else?
Also is there anything i should be looking out for? i've heard the panoramic roofs can be troublesome at times?
This is the X5 I'm thinking of viewing...
http://www.autotrader.co.uk/classified/ ... ogcode=dsp
Is there are any must have extras? This one looks quite kitted out!
Anything else?
Marrow
Re: E70 LCI Buying Advice
I bought almost the same car 1 month ago but white from main dealer slightly less mile but 2k more so I would say that's a good deal. Great car so far !
- bubbabear
Why does it not have paddle shifts?
X5 xdrive30d sport 2012, past E39 530i sport touring , e46 330ci.
Marrow
[quote="bubbabear"]
Mine doesn't have padles?
graemeX5
I think they were fitted to later E70 cars I.e 2012 onwards from what iahve seen but X5sport will confirm this
Marrow
Maybe a retro fit ?
- bubbabear
Check the corrosion on the centre hubs of the alloys- mine have got considerably worse in 6 months
Paddle shift was a cost option on many E70 trims, whether LCI or not. Only standard on the X6.
Never anthropomorphise computers. They hate that.- kenniff
Also, not guaranteed to have 8 speed gearbox, that came later than the first LCIs
Current: M50i arctic grey (G05)
Previous: RRS P400 HST, F15 M50d,F15 30d Msport, E70 35d Msport, 530i, Boxster, 330Ci Sport Vectra GSi, Chevrolet Lumina, Vxl Astras
It'll be allright in the end. If it isn't allright it isn't the end
rickz
Am I doing the right thing trying to stretch to a LCI model or would it still be okay buying a pre-LCI which will probably be a couple of grand cheaper...
Aff
Rickz, spend the extra few k and go for the LCI, a no brainer if you can make the stretch in my opinion. CIC system which is miles better than the CCC, 8 Speed GB, upgraded front and rear lights with slighly improved body. Obviously you already kniw all this... Just picked my early LCI up (2010) and abosuletly love it having moved on from my 2997 335d (CCC).
Hope this helps
Hope this helps
- chris.t
As said above the 8 speed box and updated idrive are worth the extra so if you can afford it then do it you wont regret it :xmasgrin:
Present 2016 Audi S8
Previous 2014 BMW 640d msport
Previous 2012 BMW X5 30d msport
