3.0d temp gauge
mattyp
3.0d temp gauge
My temp gauge reed just under the quarter mark on the gauge. Is this normal for a 3.0d?
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 3.0d Current Car
2002 X5 4.4i gone
mattyp
Re: 3.0d temp gauge
thanks is this a common fault with them?
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 4.4i gone
Entwicklung34
Re: 3.0d temp gauge
Got this on mine, but moves between 1/4 mark and just under 1/2 mark depending on conditions... Think mine needs changin too. (Normal is 1/2 way mark once up to optimum temp on any car i've ever owned)
Re: 3.0d temp gauge
Very common as the cars age. Might be guidance about changing them on the forum.
andym3
Re: 3.0d temp gauge
When the weather is as cold as it is my temp gauge sits just over the 1/4, in summer closer to 1/2!
If I had a problem with my thermostat wouldn't the heater not work? :-[
CURRENT CARS - E53 X5 3.0d & E30 325I CONVERTIBLE
Re: 3.0d temp gauge
Sounds like the thermostat to me, it should reach and stay at the 1/2 way mark whatever the weather after a good run, may take longer to warm up though.
andym3
Re: 3.0d temp gauge
I have no issues and the heater is warm after about 5mins of driving!
Re: 3.0d temp gauge
Different pumped and controlled circuits and the heater air runs at a lower temperature - well below coolant temp. The idea of the stat is that the temp gauge doesn't move regardless of the air temp - whether hot or cold. My E53 stayed centred all the time frosty or baking.
Re: 3.0d temp gauge
[quote="andym3"]
Look up hidden menu, this can give you the coolant temperature . The BMW gauge will stay central usually between 95 - 110 degrees, the hidden menu will give you accurate coolant temperature.
I think guessing from my poor memory thermostats tend to hold 95 / 97 degrees.
I suspected mine on the 3 er was stuck open, but it's just taking a lot longer to get up there but always settles at 97 degs C
mattyp
Re: 3.0d temp gauge
I have ordered a new thermostat, going to fit it at the weekend. What is the best way yo bleed the system ?
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 4.4i gone
Entwicklung34
Re: 3.0d temp gauge
Are you planning on changing out the water pump or coolant while you're there mate?
I think i'm going to need to do mine at some point too, so let us know how things go...
mattyp
Re: 3.0d temp gauge
Just the stat and coolant
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 4.4i gone
mattyp
Re: 3.0d temp gauge
Changed the stat and put new coolant in, it's a bit tight for space changing it. Now the gauge sits at halfway now
2002 X5 3.0i gone
2002 X5 4.4i gone
2002 X5 4.4i gone
mikem
Re: 3.0d temp gauge
Matty, can you tell us what the OBC hidden reading is with a new stat ?
