X5 MSport 2010 Rear Camera question
JimmySpeed
Re: X5 MSport 2010 Rear Camera question
Post by JimmySpeed » Wed Nov 18, 2015 4:18 pm
Put the last 7 of your VIN in there for a full buildsheet:
http://bimmer.work/
damiandavis
Post by damiandavis » Wed Nov 18, 2015 8:44 pm
Yep, done. No listing for rear camera... makes me wonder if i the cabling on the aftermarket camera matches an oem parts cabling, and i can swap it out.
Marrow
Post by Marrow » Thu Nov 19, 2015 12:03 pm
Is it hard / expensive to retro fit ?
damiandavis
Post by damiandavis » Thu Nov 19, 2015 1:40 pm
not sure - there are instructions out there to retro fit the camera and i assume that all the required cables will be in place for my aftermarket unit - apparently it doesn't need coding in either - not sure if this is accurate though.
damiandavis
Post by damiandavis » Fri Nov 20, 2015 9:09 pm
chatuge
Post by chatuge » Fri Nov 27, 2015 11:09 am
It can be retrofitted with the lines, butu needs a special tool from BMW which are like rocking horse doodoo! I only know cos back in 2009 I bought a new X5 and then asked them to retrofit the camera and they had to borrow the tool as it was so expensive. So sounds to me like whoever fitted it didn't bother doing that calibration bit cos they didn't have the tool.
damiandavis
Post by damiandavis » Sat Nov 28, 2015 9:53 pm
interesting. I'll live with the lack of lines then - no biggy!
