new screen
petershamu
new screen
Post by petershamu » Mon Nov 02, 2015 10:20 pm
Hi,
my new x5 hasa  mk4 sat nav, buggered so going to send it for repair or buy a new one??
also screen flickers and go's off for long periods of time. so am going to get a new one.
its a motorised one with the tape deck behind it.
i would like to keep it oem as i dont want to lose the features such as heater timer and so on.
any reccomendations??
also can i fit the screen myself??
thanks Peter
Steamyrotter
Re: new screen
Post by Steamyrotter » Mon Nov 02, 2015 10:48 pm
Might be wrong, as i have the MID unit..
Doesn't the Nav unit drive the screen...
The 2 could be related to just the NAV fault???
Please note...
petershamu
Re: new screen
Post by petershamu » Mon Nov 02, 2015 10:50 pm
i thought that,
but when i take the sat nav unit out it looks like it reverts to a previous mk3 or something.
but the screen flicker is with both sat nav unit in and out
Steamyrotter
Re: new screen
Post by Steamyrotter » Tue Nov 03, 2015 1:14 am
Personally I would wait till you have repaired the NAV unit then go from there, just in case..
As for replacing the screen unit yourself then it is an easy job (apparently) and there are How to remove them posts and videos available on t'net..
regards
Please note...
Denis O
Re: new screen
Post by Denis O » Tue Nov 03, 2015 5:23 am
I'd agree with Steamy. Any problems are usually down to the Mk 4 unit so get that repaired first and see what happens.
The screen is fairly easy to take out and there's usually plenty around on eBay.
05 Mercedes SL350
Steamyrotter
Re: new screen
Post by Steamyrotter » Tue Nov 03, 2015 10:56 am
And if you do change it, can I have your old one as I have a little project in mind!!!!
(Because I haven't enough to do on my car!!!)
Please note...
Colin
Re: new screen
Post by Colin » Tue Nov 03, 2015 8:20 pm
I could not be bothered with the hassle any longer ,  no bluetooth poor satnav  and the screen going off and running the battery flat overnight , got the whole lot removed and replaced even the speakers , for me it was the correct move im more than happy
05 , 30d Le Mans Blue Sport
cooa99
Re: new screen
Post by cooa99 » Wed Nov 04, 2015 9:54 am
[quote="COLIN"]
what did you replace it with?
Current Cars BMW 2005 X5 3.0d ;  Golf 2003 1.9 TDI for the High Miles Journey to work
Colin
Re: new screen
Post by Colin » Wed Nov 04, 2015 8:47 pm
an alpine ine-w997d head unit , 4 / 8inch mtx speakers sub and large amp , rear camera in number plate surround , all works via touch screen OR , voice command via siri which is awesome , still have mpg readout on dash display outside temp etc , my webasto heater works by remote so the loss of the obc doesnt matter ,
