hi on my x5 i just picked up, only the drivers dash speaker seems to work??
tried fade on the screen so assume its the speakers themselves??
speakers
Re: speakers
Probably the amp. It's in the boot and can be fixed as well as upgraded. Search the forum for references to Baris.
Worth checking all the connections. The wiring is all down by the battery - under the spare wheel & you need to remove the air compressor dome to get at it. It might be a water leak
