Code x5
Gashead
Re: Code x5
Post by Gashead » Sat Aug 15, 2015 12:53 pm
Hi, new to the X5 and coding! My E70 is a 2012 build on a 62 plate, and two weeks in am delighted with it. I read with interest the possibility of coding the mirrors, rather than having to push the button each time, so I purchased the requisite adaptor and Carly App. I'm pretty sure I have followed all the steps and the App allows me to enable the feature and writes the code back to the car ok, but sadly it doesn't seem to work, even if I hold the lock button on the fob. I did manage to code the digital speedo, so I don't think I'm doing too much wrong. I'm wondering whether my car does not have the required options to support this feature. Can anyone tell me what options are needed to support this? Thank you
bubbabear
Re: Code x5
Post by bubbabear » Thu Aug 27, 2015 9:13 pm
It will be able to do it. Where are u based?
X5 xdrive30d sport 2012, past E39 530i sport touring , e46 330ci.
splang
Re: Code x5
Post by splang » Thu Aug 27, 2015 9:44 pm
Should work - go back into the app and reconnect and check the settings have saved....
kjb1
Re: Code x5
Post by kjb1 » Thu Aug 27, 2015 10:01 pm
[quote="Gashead"]
coding needs to be selected in two places for the autofold mirrors!! happened with two X5's i did via icarly.  No longer have X5 so cannot go and tell you which menu it is, but basically have a good look at all the module settings and there is another there for coding folding mirrors!!
Sent from my iPhone
bubbabear
Re: Code x5
Post by bubbabear » Thu Aug 27, 2015 11:13 pm
You need to code CAS and FRM modules for mirrors to fold
The Mechanic
Re: Code x5
Post by The Mechanic » Fri Aug 28, 2015 4:46 pm
I have tried to get the Carly app from the App store but it keeps telling me that it is unavailable.  I managed to get the Lite version via the Carly website but still don't know where I can get the full app from.  Any tips?
Never knowingly underfed
2012 E70 30d M Sport
PhilT
Re: Code x5
Post by PhilT » Fri Aug 28, 2015 4:57 pm
[quote="The Mechanic"]
Are you trying to get it on an iPad or iPhone? If on an iPad you need to change the search parameters to "iPhone only" or it won't show up in search results.
HTH
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
The Mechanic
Re: Code x5
Post by The Mechanic » Sun Aug 30, 2015 7:46 am
Ok thanks.  I've got it now.  Can I still use it on iPad?
PhilT
Re: Code x5
Post by PhilT » Sun Aug 30, 2015 4:20 pm
Yeah, absolutely. I run it on my iPad not iPhone  :)
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
Zoomzoom
Re: Code x5
Post by Zoomzoom » Tue Oct 06, 2015 9:52 pm
:beer2: :beer2
Utterly brilliant thread!
Followed instructions on here, picked up an ELM 327 adaptor and coded those mirrors to auto fold.
Was confused when it did work after setting on CAS but then saw this:
[quote="bubbabear"]
Also done digital speedo and auto locking doors at 4mph.
The number of options available is huge and I will play with these settings later!
At £45 it is terrific value !
Z
splang
Re: Code x5
Post by splang » Fri Oct 09, 2015 10:07 pm
Glad it helped!
ajp558
Re: Code x5
Post by ajp558 » Sat Oct 10, 2015 7:48 am
They also keep improving and adding new settings.
A few weeks ago I was able to code my E70 to be able to close the powered tail lift using the dashboard button or the remote control, and not just the button in the tailgate itself.  As standard, you can only open the tailgate from the dash button or remote, but could not close it. It's a small improvement, but it all adds to the user experience and enjoyment of our BMW.
simontaxi
Re: Code x5
Post by simontaxi » Sat Oct 10, 2015 8:16 am
[quote="ajp558"]
Could you please share how you did this please ?
bmw x5 3.0 sd 08 plate
moggyboy
Re: Code x5
Post by moggyboy » Tue Jun 14, 2016 12:39 pm
I'm the first to admit that I'm a techy retard but after reading these posts I thought,"even I could do that" so I bought the Carly app and the ELM327 and I failed.
I cant get past the first hurdle of the bluetooth connection. The app tells me that I have to buy the Carly adapter? I'm reluctant to spend another £40 on an adapter when several of you on here got the coding done using the ELM327.
Any helpful suggestions would be very appreciated.
Update
OK I got the Bluetooth working and did a diagnostic check of all ecu's. I got some error codes some of which I'm not to sure about so I will investigate them later but non to do with engine as far as I could see.
Then I went to do the mirror coding and the CAS bit was applied fine but when I tried to apply the FRM bit my heart sunk.
See my post "Bricked FRM"
