Bmw x5 e53 self levelling suspension inactive
Steve
Hi I've got a message on my x5 saying self levelling suspension inactive I've checked all the fuses replaced the rear sensors but still get the ding and the message there's a code on the laptop (57 level regulation ) the suspension is ok no problems and I still hear the pump every now and then has any body had this problem ? Any help would be much appreciated
- briankerrys47
Re: Bmw x5 e53 self levelling suspension inactive
First port of call check Battery
SlimX47
Welcome Steve!
I had a similar problem a while ago- mine was self inflicted, reversed into a skip that was on my drive, cracked rear light, water got in, tailgate drain holes blocked so water went down the flexible cable duct and filled up the battery compartment where all the electronics live! There are no drain holes in it, so ended up with about 5cm of water sloshing about, which buggered the suspension control box! Picked up a used unit from eBay (about £60) after draining the battery compartment and fitting new rear light. Quite a costly and annoying affair all round!
In short, could be the control unit gone if the other components are ok...
Best of luck with it
Si
Si
