Hi all,
I am looking for two sets of wheel spacers 15mm to the front and 25mm to the rear.
Must be hubcentric.
Many thanks
Wanted - E53 wheel spacers
Re: Wanted - E53 wheel spacers
I got my Hubcentric 35mm rear spacers from e-bay... but they were quite expensive for what they were...
On the Front, I have Viper 15mm spacers.
Neither have hinted at producing loose wheels, & the wheel nuts have not pulled or let go in any way of 20k miles without removing the wheels..
I am about to get a whole bunch of bankrupt stock parts -
E53 spacers included, "Viper-Performance" 10 - 15 - 20 - 35 - & 45mm spacers.
the 20mm & wider items are threaded and have a set of studs to bolt the spacer to your hub, then use your original studs to anchor to the spacer
In my opinion the Vipers are a stronger Aluminium, as the hubcentric items I bought are easily dented & seem very soft.
Either way... neither have fallen off or show any signs of failure in any way - after a thorough examination recently.
PM me if you are interested in any items.
