Now it's my turn ! Door handle not working......
RoShamBo
Post by RoShamBo » Fri Aug 28, 2015 10:50 am
Hi guys,
Well known issue on E53 X5's - I have read enough on here about it !!
Now it's my turn, went to open my drivers side door yesterday and handle just pulls and doesn't open the door.
While I can still get in / out the car by lowering the windows and reaching in and opening from inside.....its a pain in the a55 !
There are DIY guides on here but to be honest my skills stop at changing a bulb - If I attempt it I know I will probably do more damage - so I guess it's off to a garage to fix.
Any idea on likely cost ? Pains me that I can't do it myself and save myself a small fortune, but that's the way it is !
Cheers for any help
Ro.
steve1986
Re: Now it's my turn ! Door handle not working......
Post by steve1986 » Sat Aug 29, 2015 10:31 pm
Hi,
After putting my post on i see you have had the same problem,
must be something in the air haha
not in essex are you  :)
2006 E53 X5 Le Mans Sport Exclusive Edition
1993 E32 740i
exevo
Post by exevo » Sun Aug 30, 2015 4:24 pm
Hi all,
Well that makes 3 of us with the same problem at the moment.
Must have blown up from Essex to Suffolk
[align=center]2005 X5 4.8is le mans edition
[center]gone but not forgotten.........
e39 530d
E36 m3 evolution
E21 323i
plus quite a few ol jalopies[/align]
RoShamBo
Post by RoShamBo » Mon Aug 31, 2015 7:57 pm
Ha ha ! Good to know I'm not alone right now.
How are you guys fixing yours ?
Ro.
iff26
Post by iff26 » Tue Sep 01, 2015 9:35 am
if handle is not broken yet but very stiff. Remove internal door cover,fixed with 4-5 screws,cant remember exactly.disconnect  window switch and remove airbag unit(if you struggle search youtube) take WD40 and aim all the moving parts,most importantly try to aim inside cable sleeve!! Put all back together,move handle 5-10 times, after couple hours it should work smoothly again! worked for me and for other 2 two lads! looking about 15-20 min job,easy breezy, good luck!!
X5 4.4is  EX Carbon Black
X5-D-Sport
Post by X5-D-Sport » Sun Sep 06, 2015 7:22 pm
I have the door handle issue too, but managed to fix it with the cable tie trick - excellent, but now it seems the mechanism on the door shut end under the handle now needs tinkering with.... damned cars lol
The handle mechanism is fine, the lifter is fine.... now I gotta fiddle with the locking block...
