Start button just clicked - twice now
- pvr
Two weeks ago, drove to NL, parked up overnight and the next day the car just clicked when pressing the start button. It did it 3 or 4 times and I switched off the airco just in case, and it started absolutely fine.
Last week again, the car had been on the usual charger since I returned form NL and the first press of the start button, again just a click. Again, the airco button was on - I switched it off, tried again and starting fine. No other starting problems afterwards.
Car just ticked over 14k miles now and is always on a CTEC so battery fully charged.
Thoughts?
Thoughts?
911 50th anniversary -
- kjb1
Re: Start button just clicked - twice now
loose connection somewhere on battery system!! starter not receiving full power. Check the jump start point in engine bay also, as mine was loose here and causing starting issues similar to yours! get a spanner on the connection and nip up, to be sure.
Sent from my iPhone
Sent from my iPhone
- pvr
Interesting point - I always use the jump point for the ctek so could have got a bit lose. Will have a look at that first and follow the starter motor cables along to see if all is tight there.
Never been an issue, just a couple of times now in a few weeks. No error messages either.
Problem with the ac system resulting in a starter inhibit? Can't think of why though as it's not as if the compressor clutch is engaged all the time - or maybe that is the problem and the car sees the clutch as engaged at start when perhaps it shouldn't be.... ???
Never anthropomorphise computers. They hate that.- kjb1
[quote="pvr"]
Sounds too familiar PVR, mine had no fault codes as such, and would just click! fail every now and then, started getting more frequent until point of failure and a tow to dealership ensued. They found it straight away after seeing battery was healthy. I split the connector down in the end and sand papered all the washer / nut / bolt etc, and got it all to fresh metal, then copious amounts of vaseline and never had a start issue afterwards.
Might not be your issue but always worth checking hey. Nip up with a spanner, mine had a few mm of movement first time round, not much, but enough to cause issues.
Amazing that to look at and feel by hand all would seem well, but putting a spanner on it and getting a few mm movement on the bolt made so much difference!!
Sent from my iPhone
Sent from my iPhone
- 535dboy
Part ex for a new one
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
- pvr
[quote="535dboy"]
With 14k on it? Think when I consolidate cars at some stage (i.e. when TVR's car gets here and there would be 7 then), that I would look at something completely different.
- 535dboy
[quote="pvr"]
[quote="535dboy"]
An electric scooter? They'll be having your license of you soon given your recent big birthday.
In fact do you even have a UK licence?
[quote="535dboy"]
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
- pvr
Regrettably, yes - I do have a UK license as I was "forced" to swap mine due to insurance companies in the late eighties refusing to insure a UK car driven by a NL license holder.
I have been trying to swap it back but without a permanent address in NL it is not possible.
- 535dboy
They will refuse to insure you anyway soon so hardly a major issue.
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
- pvr
On topic - I have now tightened that bolt and will see if that helps. That hole point is a bit wobbly though, I might take it apart and use some of the KY that 535dboy left behind a few weeks back
- kjb1
[quote="pvr"]
whats the latest?
Sent from my iPhone
whats the latest?
Sent from my iPhone
- pvr
Uh.... I have not driven the car since
Next drive is on Tuesday
- 535dboy
[quote="pvr"]
And !?
And !?
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
- pvr
Did not take it as I took the Golf - the weather was nice.
Had to drive through that sodding diversion in your village >:(
