X5 E70 Voice Control
Hi All
Just got me a 2011 AUC X5 Xdrive3.0d monster.
Playing with all the bits in it, as you do, ive discovered the voice commands. Cutting to the chase, i can only seem to get it to offer commands for phone options and nothing more. Ive got bluetooth audio streaming working via the phone and Nav in a CIC Professional setup, so assume i have the correct setup, but how do you get the rest of the voice commands working.
Ive tried while being on the navigation option then pressing the voice button but it only asks for name or number, if i say help it says options but they are all phone related like "Call Name" "Call Number" etc....
Am i missing something here or do i need another "option" purchased for voice commands other than phone to work?
Any help is appreciated
Re: X5 E70 Voice Control
Check whether 'Voice Control' is listed in the options. You might just need the BMW retrofit kit which could be no more than an expensive licence key - called an FSC Code - to enable it.
Thanks X5Sport
Options dont list it see below, so its an additional extra then, can i get the FSC code cheap and how would it be installed if it can be done without the stealer!
1CA SELECTION COP RELEVANT VEHICLES
1CB CO2 CONTENT
2PA LOCKING WHEEL BOLTS
220 SELF-LEVELING SUSPENSION
230 EU SPECIFIC ADDITIONAL EQUIPMENT
255 SPORTS LEATHER STEERING WHEEL
302 ALARM SYSTEM
316 AUTOMATIC TAILGATE OPERATION
328 ALUMINIUM RUNNING BOARD SILL
386 ROOF RAIL
4AD INTERIOR ALUM. LENGTHWISE FINE
423 FLOOR MATS, VELOUR
428 WARNING TRIANGLE
430 INT/EXT RR VW MIRROR W AUT ANTI-DAZZLE
431 INTERIOR RR VW MIRROR W AUT ANTI-D
441 SMOKERS PACKAGE
5DA PASSENGER AIRBAG DEACTIVATE
502 HEADLIGHT WASHER SYSTEM
508 PARK DISTANCE CONTROL (PDC)
521 RAIN SENSOR
522 XENON LIGHT
534 AUTOMATIC AIR CONDITIONING
544 CRUISE CONTROL WITH BRAKING FUNCTION
563 LIGHTS PACKAGE
575 ADDITIONAL 12V POWER SOCKET
6AA BMW TELESERVICES
6AB CONTROL TELESERVICES
6FL USB-/AUDIO INTERFACE
6VC CONTROL COMBOX
609 NAVIGATION SYSTEM PROFESSIONAL
612 BMW ASSIST
615 EXTENDED BMW ONLINE INFORMATION
616 BMW ONLINE
633 PREP.MOB. PH. BUSINESS BLUET.INTERF.
654 DAB TUNER
694 PREPARATION FOR CD CHANGER
698 AREA-CODE 2
8KA OELSERVICE INT. 30.000 KM/24 MONTHS
8SC COUNTRY SPEC. RELEASE OF TELESERVICE
8SM VIN, VISIBLE FROM OUTSIDE
8S2 CODING OF ALARM SIGNAL
8TG ANTI-THEFT SYSTEM
8TL DAYTIME LIGHTS FRONT AND REAR AKTIV
8TN DAYTIME DRIVING LIGHTS SELECTABLE B
812 ENGLAND VERSION
877 DELETION CROSS-OVER OPERATION
880 ENGLISH / ON-BOARD DOCUMENTATION
925 SHIPPING PROTECTION PACKAGE
1CB CO2 CONTENT
302 ALARM SYSTEM
386 ROOF RAIL
441 SMOKERS PACKAGE
521 RAIN SENSOR
522 XENON LIGHT
563 LIGHTS PACKAGE
6VC CONTROL COMBOX
612 BMW ASSIST
616 BMW ONLINE
654 DAB TUNER
698 AREA-CODE 2
812 ENGLAND VERSION
I have the same problem i am missing option SA620. I posted a thread on bmw coders but no reply
Do you have auto folding door mirrors?
X5 xdrive30d sport 2012, past E39 530i sport touring , e46 330ci.
I have a button that i can press and it folds the mirrors but it doesn't do it when i lock the car, i believe that's a coding job that needs to be done, im going to try that when i get my cable
Yes thats correct with your options you can code your keyfob to open/close the door mirrors and the tailgate. Check with your dealer if your car needs a firmware update...to increase security against theft, no charge.
Also check the sat nav map version since this can be upgraded to 2015-2 (i assume you have Europe Premium?)
You can also update the telephone and multimedia software free via usb stick link :
http://www.bmw.com/com/en/owners/connec ... pdate.html
Hope this helps
Bubbs
Hope this helps
Bubbs
Thanks Bubbs
I already got the FCS code from a chap online and upgraded the maps, had 2011 so got the new 2015-2 Western Europe one. Dont really see any real difference to be honest. Just updated roads i suppose.
The keyfob already has a little boot icon on it and when pressed opens the boot, if you hold it then it closes the boot also. What i will look to do is code the button in the car to close the boot (if possible) as it only opens it at present.
Bluetooth update is also done. Again it was all working fine before i did it so not sure what its changed (other than bug fixes) but i like to keep things current if possible. Gutted i dont have the full voice package though. Ill ask my local dealer what the deal is with that, probably a lot more money than its worth! :-[
Mine had the bmw security firmware update today...i cant see any difference but hopefully will be to potential thieves.
I need to do my satnav maps can you recommend the person you used. pm me if you like thanks
Bubbs check ya PM
I enquired about SA620 retrofit and was told by my dealer (south west coast) that they had spoken to bmw uk about this potential job. The feeback was that it would not be feasible because some wiring would be required to be connected to the sat nav so cost would be ££££ in addition to the software coding.
Unless someone else hears otherwise i will assume this is a dead end.
There are a whole load of retrofit kits listed by BMW on Realoem. Correct one depends upon your specific options list....this is the list against my E71 and it will have an equivalent for the E70 as the electronics are pretty much the same.
http://www.realoem.com/bmw/enUS/showpar ... Id=84_0917
Have a look and see if one fits yours, then quote that number to BMW. Many dealers cannot work their own parts systems!! It quotes US/CDN against some options but that appears in all the EUR versions too.
There seems quite abit of confusion here regards to Voice control on the E70/71 platform,if you have the Pro Nav and the bluetooth which allows mobile calling the required hardware is already installed (voice button on wheel and cable to Navigation unit) its just a case of activating the SA620 VoiceControl by purchasing the required fee from BMW plus adding the option to the VO and thats all is needed albeit at an expense that could could many off the idea!
Lee
Lee
Bmw want £420 for the code + 1hr labour = £500+
[quote="bubbabear"]
It's steep for a relative simply procedure shameful nothing more than that,if BMW wants more business through their doors it can't be wrong reducing the costs of retrofits that many ill advised customers at point of order failed by unkowledgeable sales staff in the first place!
Hey Mpower, Can i code this option in myself? Been thinking about doing so coding so if this is something i can do then its even more tempting.
I assume adding the option to the VO is the coding part but activating the SA620 would need a FCS code?
Rob
Rob
