Aux fan running if!!!!
Micevo
Post by Micevo » Thu Jul 09, 2015 7:36 pm
Just one more question before I have to take it in to a garage : (
Here goes got another fan still didn't work but know its a good one,
Today I tried this I took the connector off the low pressure AC switch and the fan came on with AC  on and turns off when AC  off, not tried it to see if fan comes on when car is at the required temp for aux fan to come on,
Also it throws EML  on if stood in traffic and set temp for fan to come on is reached! Put scanner on and only comes up with aux fan fault and can't get more info,
Q1 could it just be the AC pressure switch?
Q2 must be a relay somewhere but can't find it?
Q3 anyone had this prob an got it sorted?
TimX5
Re: Aux fan running if!!!!
Post by TimX5 » Thu Jul 09, 2015 8:07 pm
I had mine checked out by a friend who tried to power up the fan via the diagnostics but no joy so I think the fan is knackered , where abouts is the ac low pressure switch.
Micevo
Post by Micevo » Thu Jul 09, 2015 8:46 pm
Left  hand side at the bottom on the thin AC pipe 3 thin wires, disconnect put AC on with engine running and see if comes on !!!
Mine did must be a relay hidden somewhere I think cus I'm sure they are slow an fast running fans,
Micevo
TimX5
Post by TimX5 » Thu Jul 09, 2015 8:49 pm
Cheers I'll go check mine , the fan is variable speed I believe.
TimX5
Post by TimX5 » Thu Jul 09, 2015 8:59 pm
I unplugged the low pressure switch while the ac was on and the ac clutch disengaged and the fan twitched and that's all that happened,  connected the switch up and the ac pump started again .
AW8
Post by AW8 » Thu Jul 09, 2015 9:12 pm
I did PM you but this may assist in addition http://www.laczik.org/BMW/repair/E38_au ... x_fan.html
TimX5
Post by TimX5 » Thu Jul 09, 2015 9:23 pm
[quote="AW8"]
Thanks AW8 but my fan doesn't work at all
X5-D-Sport
Post by X5-D-Sport » Sat Jul 18, 2015 11:16 pm
Where is the low pressure switch on a 3.0d face lift...
I read that the connections can be shorted & will poss kivk the fan into life ??
TimX5
Post by TimX5 » Sat Jul 18, 2015 11:27 pm
Read post #3 above , disconnect it with the ac on and it should work , I've fitted another fan to mine and it's fixed.
