Good Morning All,
I am trying to purchase a Bluetooth ODB connector that with work with my X5 E53 03 and the Torque application?
Has anyone had any sucess.
I ihave an aftermarket head unit and wish to pick up the MPG since a recent terraclean.
Stuart
Torque App Bluetooth ODB Connector? Need to review MPG post TerraClean.
jangle
- Greydog
Re: Torque App Bluetooth ODB Connector? Need to review MPG post TerraClean.
I have an ELM327 it works well with my lap top (ubunto) and my padfone which has Torque loaded
hope this helps
hope this helps
jangle
Greydog,
Thank you.
Where did you purchase the unit from ?
Stuart
Thank you.
Stuart
- Greydog
From Ebay about 3 years ago was about £5 if my old brain is right
jangle
Yeah then this is the same unit I have purchased, it pairs with the Android unit but when you run Torque after telling it which OBD it says unable to retrieve any data.
I have since purchase a further 3 OBD connectors and only my USB with BMW Scanner work the Bluetooth seems to fail.
Any ideas where I may be going wrong?
Stuart
Stuart
- Greydog
If your Headunit is finding and linking with the Bluetooth Dongle OK, it should be automatic if the Dongle is plugged in. Then I would look at the Torque App, has it installed correctly?
Just a thought do you have your phone connected as well? If so try it with your phone off. While your Bluetooth may register a number of devices it is a simple system cant handle simultaneous transmissions.
Dave1987
STEP 1: Plug ELM327 Bluetooth into Car's OBD Port
STEP 2: Turn ON Car Ignition. This is one step before engine is powered.
STEP 3: Pair ELM327 Bluetooth
On your device — go to "Settings" > "Bluetooth". Connect to Bluetooth signal with name similar to these examples: OBDII, ELM327, VLink, Can OBDII, etc.
NOTE: It can take up to 30 seconds for Bluetooth signal to show.
Pair code: 1234
If above doesn't pair, then: 0000
STEP 4: Configure OBD App To Detect Bluetooth
Launch your OBD App,Go to Settings and configure it to look for Bluetooth.
STEP 5: Connect To Your Car
OBD App should now successfully connect to your vehicle.
NOTE: If OBD App still doesn't detect the Bluetooth connection — then force quit the app and launch it again. (To force quit inside Android, use "Task Manager".)
Pair code: 1234
