Where to begin!
Got the car about a week ago so just learning my way around it, first problem is aircon not working, had it regased as it was empty, now still not working, compressor clutch is engaging when switched on and disengages when turned off, so presume that's ok,
Aux / pusher fan not coming on, I've put a volt test on the plug and get 12.6ish V from red wire, thin wire 0.003 when not turned on, an about 3v when aircon turned on, brown wire no volts so presume earth?
Does this fan have to be on for aircon to work? Eg no fan no aircon or will aircon still work without fan and I need to look else where?
All ideas will be greatly appreciated ,
Other niggles I have with it
Passenger window sticks down, need to replace a plastic thingy ordered
Headlight washer not working , new pump ordered just arrived will do today
Pixels in radio mid not good looking into sorting that, might just get a ribbon or send it away
Oh yea parking sensors what a pain got front drivers side not working so none work , is there any way of disabling just the front sensors?
