iPhone 6 compatability with iDrive
RRH
Post by RRH » Mon Jun 15, 2015 2:34 pm
Hi, just bought my 2nd X5, a 2008 sd.
I have a Y cable, which was with the car, works fine and gives control of iPod through the iDrive.
However, I've bought another Y Cable as I have an iPhone 6. No such luck with this phone, iDrive ignores it.
Any ideas?
Simon
kenniff
Re: iPhone 6 compatability with iDrive
Post by kenniff » Mon Jun 15, 2015 2:43 pm
Did you buy a new cable because the connector in your Iphone 6 is different from the ipod?
If so, I suppose there are 2 possibilities:
1. The new cable is the problem.
2. The new phone is the problem.
You could maybe buy a little converter adapter from apple
http://store.apple.com/uk/product/MD823 ... in-adapter
and if the old cable plus adapter doesnt work with your new phone then its the phone thats the issue?
Mind you, the connector is £25....
Good luck
Current: M50i arctic grey (G05)
Previous: RRS P400 HST, F15 M50d,F15 30d Msport, E70 35d Msport, 530i, Boxster, 330Ci Sport Vectra GSi, Chevrolet Lumina, Vxl Astras
It'll be allright in the end. If it isn't allright it isn't the end
RRH
Post by RRH » Mon Jun 15, 2015 3:04 pm
Yep, its the lightning connector on the new phone, bought a lead off amazon (£7) rather than from BMW (£50+) as from what I can gather it's essentially the same.
I suspect the lightning connector on the iphone 6 doesn't carry audio.
Riggie
Post by Riggie » Mon Jun 15, 2015 7:07 pm
I'm assuming you have a usb in the cntre console? Mine is a late 2009 and doesnt have one in the centre console but does in the glove box for uploading stuff to the hard drive. Not sure if I can connect to that, of so, I'll get a cable.
brewer
Post by brewer » Tue Jun 16, 2015 9:56 am
[quote="RRH"]
Surely if the lightning connector didn't carry audio no docks would work?!  Definitely NOT the connector.
Post by X5Sport » Tue Jun 16, 2015 6:24 pm
The lightning connector has a chip in it that reconfigures the pins and it may not correctly read the car USB setup so not put the audio onto the correct pins.
Apple never make anything easy do they!
RRH
Post by RRH » Wed Jun 17, 2015 9:54 am
What a complete pain in the arse!
