new car retrofit options and connected drive
exon16m
Post by exon16m » Sat Jun 06, 2015 9:34 pm
What can be easily done.
I have bmw remote but can only lock unlock and locate car should other options be avaliable on a cic prof (e70 2013)
I have seen some electronic mods such as the bmw apps but have not managed to work out if its a dealer thing or if it can be diy
any help appreciated?
bubbabear
Re: new car retrofit options and connected drive
Post by bubbabear » Sat Jun 06, 2015 9:38 pm
Not sure if you are referring to coding but things like closing boot and folding door mirrors are possible
X5 xdrive30d sport 2012, past E39 530i sport touring , e46 330ci.
bubbabear
Post by bubbabear » Sat Jun 06, 2015 9:41 pm
For connect drive there is a charge of £120 pa for the apps. I registered for connect drive this week but i didnt see any real benefit of these services.
Post by X5Sport » Sat Jun 06, 2015 9:50 pm
Lock/Unlock/locate within 1.5km is the UK functions limit and is controlled by the BMW servers.  As with the Apps, you need to maintain your BMW Assist subscription or you will lose access to them as the function is via the on board SIM.
Have a look at bmwcoders dot com for ideas about what can be done.  There are all sorts of tricks available if you are brave enough, have the right software and reference files (DATEN) for your car series.....and understand German as the coding is in that language.
Mirrors, tailgate opening/closing from inside (needs a powered tailgate option of course), lights, dash indications.  There are a lot of very knowledgable folks over there who can help.  Some is just a software switch but others need the right modules to be there.
exon16m
Post by exon16m » Sat Jun 06, 2015 9:55 pm
gosh 120 every year to used the features of the car. I would have been annoyed that is not on there sales book
do you know if uk dealers retrofit any of the simple code options and cost?
saucysimon1954
Post by saucysimon1954 » Sat Jun 06, 2015 9:56 pm
There is a BMW Apps retrofit kit if you have the necessary pre-requisites. These usually include professional nav, smartphone audio integration, convenience telephony.
Check with your dealer. Its going to be expensive, so don't be shocked if they quote £600 or so including labour. I had mine retro-fitted to a previous 6 series with CIC navigation.
Post by X5Sport » Sun Jun 07, 2015 10:52 am
[quote="exon16m"]
But it is.  It's part of the paid 'BMW Assist' option, not a feature of the car.  First three years are free, then you pay.
Dealers will only retrofit the official kits offered by BMW.  Anything else not part of a kit is down to each of us individually.
Mpower
Post by Mpower » Sun Jun 07, 2015 11:58 am
I'm assuming you're talking about the BMW remote App which I have and to be honest does only Lock/unlock whereas for other models they can remotely activate/deactivate a lot more and as posted free for 3 years from first subscription.
Regards to BMW Apps 6NR option which I didn't order from factory but had dealer program after purchasing the FSC code plus the cable from CIC to snapin under the armrest to save £'s fitted myself works pretty well with video stored on your iPhone on the CIC screen.
bubbabear
Post by bubbabear » Sun Jun 07, 2015 12:48 pm
I would love to get my folding door mirrors coded. Was quoted £100 is that a fair price ?
Mpower
Post by Mpower » Sun Jun 07, 2015 8:08 pm
[quote="bubbabear"]
Personally that's too much £'s for what really is a 10-20mins max to code assuming you have electric folding mirrors option fitted,find someone local to you or you fancy getting into coding buy the cable and code yourself more options!
td_100
Post by td_100 » Wed Jun 10, 2015 5:27 pm
Is there nothing similar to vagcom that is available for VW's?. I enabled Bluetooth on my old Touareg very easily
Post by X5Sport » Fri Jun 12, 2015 4:53 pm
There is.  Have a look on bmwcoders dot com.  Everything you need is on there.  You will need a laptop that can run run XP, or a VM of it in 32-bit mode.  The BMW system doesn't natively support 64-bit or OSs newer than XP.
The base data files are about 9GB though.....beware.
