unable to open drivers door
Rick
Post by Rick » Sat Jan 08, 2011 5:30 pm
Hi,i closed the drivers door as normal and when i came to open it it will not open,i have climbed through passenger side and the door CANNOT be opened from inside either,any ideas how i can open door,can the door card be removed with the door shut.I suspect the locking mechanism is u/s?
Many thanks Rick
2004 4.8is Le Mans Blue
Mods,Speaker upgrade to JL Audio C5 650 CSI Comps,Pioneer TS-WX77A subwoofer,Lazer Pro Park.
x555
Re: unable to open drivers door
Post by x555 » Sat Jan 08, 2011 5:39 pm
The door card can be removed with the door shut but it is ARPITA and you have a good chance odf damaging it.(they are about £500 new or some stupid price from the dealers)
I had to do it on my last x as the door mech had condensated and rusted.
I don't know if this post helps..........viewtopic.php?f=22&t=417
Rick
Post by Rick » Sat Jan 08, 2011 5:50 pm
I have already replaced the door carrier and removed the card in december,is there any other way of opening the door without removing door card
x555
Post by x555 » Sat Jan 08, 2011 6:02 pm
Not to my knowledge if the handles don't work.Is it really cold where you are? i ask as if its frozen etc it may thaw out with some help....probably stating the obvious here :oops: but Just a thought.
Rick
Post by Rick » Sat Jan 08, 2011 6:05 pm
Thanks for reply,its actually very mild defo not frozen as i have had that problem in the past
Rick
Post by Rick » Sat Jan 08, 2011 7:06 pm
Have just managed to remove door card,does anyone know how to remove door mech? i cant see any bolts to remove it
Thanks Rick
PhilT
Post by PhilT » Sat Jan 08, 2011 7:53 pm
Rick, not sure if your problem is the same as in the link below but it may help
http://www.xoutpost.com/bmw-sav-forums/ ... -pics.html
Phil.
Current Drive:
E71 X6 30D 2011
E53 X5 3.0D 2004
Previous:
S54 Z3 MCoupe 2002
S50 Z3 MCoupe 1998
E46 330 Ci Sport 2003
x555
Post by x555 » Sat Jan 08, 2011 9:14 pm
It's been a long while since i did mine but i never actually took the mech of. I got it open by using a flat headed screwdriver and fiddling around untill i unlocked the door (technical i know :oops: ) once it was open i could see the prblem was rust so treated it with wd40 etc and never had the problem again.
@ phil...great link that :thumbsup:
Rick
Post by Rick » Sat Jan 08, 2011 10:17 pm
Cheers Phil,followed the link and the door is now open,i thought i was in dire trouble this time,up early tomorrow to take out door mech and lube.Once again thanks very much :D :D :thumbsup:
This would fit in well on the How to but not sure how to :rofl:
x555
Post by x555 » Sun Jan 09, 2011 10:14 am
Glad your sorted now :thumbsup: a how too is a great idea take a few pics when doing the job :thumbsup:
ChewingBacca
Post by ChewingBacca » Sun Jan 09, 2011 12:04 pm
As a preventative measure is there an easy way to squirt a bit of WD40 at the mechanism without stripping the door panel off?
My drivers side seems a bit stiff.
Rick
Post by Rick » Sun Jan 09, 2011 5:54 pm
not really the mech you want to squirt is on the inside of the door sill,it is not a difficult job to remove the door card
ChewingBacca
Post by ChewingBacca » Sun Jan 09, 2011 7:28 pm
Thanks Rick.
