Diff Oil - What type is it ?
X5-D-Sport
Post by X5-D-Sport » Sun May 24, 2015 8:42 pm
Good evening Gents,
What oil does an E53 Diesel like in her Rear / Front Diffs ?
Just been underneath & spotted an input shaft diff seal leak, so I want to wiz some more oil in there while I get around to changing the seal some time.
Regards to all
kave
Re: Diff Oil - What type is it ?
Post by kave » Mon May 25, 2015 11:26 am
Front and Rear diff: Fully synthetic 75w90
I used around 2.5L in total, so you will need 3L.
This is the OE oil BMW recommend:
http://www.opieoils.co.uk/p-737-castrol ... 5w-90.aspx
Really useful checker from Castrol here:
http://oilselector.castrol.com/c/uk/eng/search
Procedure links see here:
http://xdrivers.co.uk/forum/https://xdr ... ic.php?t=2
http://www.pelicanparts.com/techarticle ... cement.htm
Its a 14mm hex socket for filler and drain plug - not a size normally carried, had to go buy a set especially for this big boy.
Good luck.
X5-D-Sport
Post by X5-D-Sport » Mon May 25, 2015 2:47 pm
Many thanks
