Hi,
Anyone can do some input on this code I know the definition but I need some more details.
Error code P3019
Re: Error code P3019
Google it with the vehicle details - probably get your answer
Trouble Code: P3019
O2S Sensor Lambda Controller Value Above Threshold due to Open Pumping Current Circuit (Bank 1 Senso
Possible Causes:
Internal HW fault in control module
What is Hw module?
Possible Causes:
What is Hw module?
Lambda sensor heating issue.
So basicly needs replacing. If it says bank 2 sensor 1, so when you stand at the fornt of the car it is right hand side and one before cat? Am I correct.
RH side is always from the seated position facing forwards.
Near side / Off side .... gets confusing depending on which side the steering wheel is fitted - from a manufacturing perspective lol
