i think i ve killed it
Ryoken
Post by Ryoken » Tue Mar 24, 2015 7:29 pm
I took my headlights off today , to give them a sand down everything was going ok , till I came to put them back on,  put both lights in , connected them back up properly , and  turned on the lights , no engine on just ignition,  it said check side lights ,my drivers indicator was on , both hids, came on  but no side light on the driver side, hmm , I thought , I cant have got them wired up wrong ,  re checked , nope all good,
decided then to fire the car up ,  it juscked and said something like engine failsafe, and it just clicked,
bugger :(
now , I re checked everything, ive done nothing wrong , tried starting again after 10 mins  im getting just a click, the battery is Very low, ill go out and check voltage,
I scanned the car using bmw scanner and ive lost 80% of the modules in there , will a really flat battery cause all these proplems??, ive no radio , no unstrument cluster , my sls is inactive again , and my gearbox electronincs  have errors
going out to test voltaqge , will post soon
steve. slightly worried now
battery has 8.65V in it
which is worrying ,
2002 e53 4.4  tempremental
2001 suzuki Hayabusa just for fun
Sanj
Re: i think i ve killed it
Post by Sanj » Tue Mar 24, 2015 7:58 pm
Its your battery buddy - charge the bugger and then watch everything come back alive. Don't worry!
Oh and if it happens again you may have a battery drain or coincidental battery on it's way out.
Ryoken
Post by Ryoken » Tue Mar 24, 2015 8:14 pm
im having to get recovery out .  they should be able to start it then I can drive it home to get charger and charge it up properly over night
you can charge battery through the  engine bay terminals cant you?
Sanj
Post by Sanj » Tue Mar 24, 2015 8:22 pm
Yeap - no probs thru engine bay.
Ryoken
Post by Ryoken » Wed Mar 25, 2015 1:47 am
nice recovery man came and jump started it , i had to turn steering wheel lock to lock , to get rid of errors, everything ok so far, ive put it on charge over night while im at work , going to get my battery tested tomorow,
im much happier
allthough ive found out 10 minutes ago ive got to remove my headflights again as i removed one of the fog light bulbs :)
what a day :)
Ryoken
Post by Ryoken » Fri Mar 27, 2015 7:27 pm
took, car to battery place today, and got the battery tested, theres nothing wrong with it , now I will throw this out , if you put the ignition on , and put your lights on (hids) how long do you think it will take before the battery drops down to a critical level. where upon trying to starting it the battery will have 8.5 v in?.
Steamyrotter
Post by Steamyrotter » Fri Mar 27, 2015 7:30 pm
Unfortunately... Surprisingly quick!
Please note...
Post by X5Sport » Fri Mar 27, 2015 7:55 pm
Too quick!  Depending upon all options fitted the current draw can be a lot.
My X6 draws almost 60A in the condition you describe.  Low battery warning goes in less than 20 minutes.
Sunnythered
Post by Sunnythered » Sun Mar 29, 2015 9:39 pm
I have 11.0 v in mine and sometimes it takes ages to fire up, can I put a charger on the battery?? It's a Bosch silver 4...
Post by X5Sport » Sun Mar 29, 2015 10:11 pm
Yes.  Connect via the jump points under the bonnet - BMW's preferred way to do it.  11.0V is a bit low.  Are you checking it when the car has gone to 'sleep'?  Wait 4 hours after last run, open the bonnet, wait 16 mins and then check it at the jumper points.
