Wheel judder and violent vibrations. Help!!!!
Steve1312
Re: Wheel judder and violent vibrations. Help!!!!
Post by Steve1312 » Thu Mar 19, 2015 6:47 pm
Yeh thanks I am getting the four wheel allignment done aswel now it's sorted
X5-D-Sport
Post by X5-D-Sport » Mon Mar 23, 2015 10:58 pm
I had EXACTLY this issue and it came in at about 60mph... release the throttle and shook like hell... blar blar blar..
Then it all changed and was ok for a mile and started again...
Got to my destination 5 miles further along...
Turned out the nearside disk & wheel were VERY HOT, the disk had Blue'd with the heat...
Sticking brake calliper was the culprit
A £35 seal kit incl brake pistons fixed it...easy job too.
I would have pit money on a wheel bearing failing or suspension joints...
Go for a drive and see if one disk heats up...may take 5 miles... bit Its worth checking before you spend hard earned cash on an aligent check...
Rob5
Post by Rob5 » Thu Apr 09, 2015 9:00 pm
[quote]So I filmed the passenger wheel whilst driving/quote]
You must have really long arms!
Steamyrotter
Post by Steamyrotter » Thu Apr 09, 2015 11:58 pm
19" wheels are normally 'staggered' so a different size wheel and tyre, rears being wider (or should be).  Front to back swap not recommended!
Do you mean the 20" wheels??
Please note...
Post by X5Sport » Fri Apr 10, 2015 8:22 am
[quote="Steamyrotter"]
Either.  20" are staggered too.......or am I being blonde :-[
Steamyrotter
Post by Steamyrotter » Fri Apr 10, 2015 1:16 pm
Aha thats where IQ went!!!
>:D
Please note...
