iPod lead?
- Winter20vt
iPod lead?
I have the factory headunit in my 2006 X5, it has an old style iPod lead connected through the glove box, I have the iPhone 5s before for I go pulling out the headunit can anyone tell me if the back of the headunit takes a USB connection for the lead or is it a lead that I will have to go out and buy? Hopefully that makes sense. It's killing me having to listen to the radio! (For some reason the 6 disc CD changer is missing :noexpression: :blink:)
2006 BMW X5 3.0d
1989 VW Golf 1.8T 20v
- Sanj
Re: iPod lead?
iPod lead? You mean you have a connection that goes into the headphone socket on your phone/iPod?
Then it's an aux cable connected behind the unit to the wiring loom and not the headunit itself (which has no USB connection btw). You have a 2006 car with a headunit almost 10 years old in tech.
- Winter20vt
Re: iPod lead?
It's an iPod cable mate that's connected to the back of the headunit (not sure how until I take the headunit out) but the lead comes through into the glove box, the end of the cable plugs into where you charge the phone, not the headphone port. Will get a picture up tomorrow
2006 BMW X5 3.0d
- Sanj
Re: iPod lead?
If that's what it is - get pics for sure and the there's a converter, think they call it scosche???
- Dr C
Re: iPod lead?
If I'm reading this right, all you need is an adapter that goes from the old-style 30 pin iPod connector to the lightening connector that will plug into the iPhone5. These £25 from most mobile phone shops, Curry's, PC World, Argos etc. I wouldn't go for a cheap one, the genuine ones are £25. Not sure if the head unit will be compatible with iOS 7/8 though?
http://tinyurl.com/q3qsq8y
Current:
F15 X5 M50d
Mark 7 VW Golf GTD
F15 X5 M50d
Mark 7 VW Golf GTD
- Winter20vt
Re: iPod lead?
You have got it Dr C! I tried a cheap converter from ebay, only a few quid but it didn't even recognise the phone was connected, now popping I to the city so will go to apple and see if a genuine converter works
2006 BMW X5 3.0d
- Dr C
centurion
Re: iPod lead?
hi... i did [plus a lot of other on this forum] set one up in my X5 with 30pin lead connected to the AUX input. all fine albeit audio levels are fairly low compared to CD/Radio levels etc. Plus the fat that if you want lightning connector you'll need another adapter...
my suggestion would be to drop in to one of prof. audio shops and discuss your requirements as they have no. of diff. solution depending on your needs and budgets.
Re: iPod lead?
Remember to turn the iPod volume output to maximum as this seems to affect the audio level though an external system too.
danny12340_5
Re: iPod lead?
Depending on the info given there was a retrofit kit for e53,46 etc that had a genuine iPod kit, when fitted if I rem correctly the kit replaces the cd changer which would indicate the fact it's removed from your car
03 carbon black edition 4.6is, champagne leather, sunroof, 20" 5 spoke, DSP
- ChrisLux
Re: iPod lead?
I've got a lead like Sanj mentioned on mine.
I plugs into the AUX socket on the back of the Head Unit and then into the headfones socket on the iFone.
Works OK except volume is a bit lower than usual sources.
sprintman
Re: iPod lead?
I have a connect2 in my car-with this you remove the 6 cd changer and is replaced with a small unit which plugs into the original cd plugs , you then run a lead to your I phone etc which could be in the glove box( mine is in the front ash tray) and then you control your I phone or whatever plugs into it just like you would with your cd player-I have an I-pod which has all the music I want on it and I just leave it plugged in all the time works well and suits me fine! also charges the I pod or even my I- phone
My other car is the wife's mini dooper( it must be mine all she does is drive it!)
rpmx5
Re: iPod lead?
I have this lead in my car, is this definately what happens to the cd autochanger? As I have no cd changer in the boot of mine. Was looking at buying one off eBay as my car is autochanger ready? But if the ipod/iphone connector is connected where the cd is suppose to be
