Slow to Pull Away
7builder
Re: Slow to Pull Away
That's good to know Tim. Is your X5 a facelift model. Mine is a prefacelift so I guess the filter is in the engine bay. I'm not with the car today so can't check for myself until later
storminmike
[quote="TimX5"]
I renewed my fuel filter yesterday , went out in the car this morning outside temperature was below 3 enough for the car for pre heating to be activated , even though glow plugs don't work on mine lol and it felt more lively than it did before so it's done some good and the fuel injection warning light no longer comes on when you kick down.
Really...it's feckin cold out there and you did that in a morning! Must be getting soft as it has to double figure temp for me to crawl about under the car. It's snowing here now as well
Mine's not got running boards...does that make it easier or no difference at all to get the bottom panel off?
storminmike
[quote="mark hamster 28"]
i had this exact problem on my range rover sport 3 years ago.! On that it was the EGR valves. New ones fitted and problem gone. Dont know if this will help as different car but just thought i would mention.
That's on my summer list to do...which is growing
TimX5
[quote="storminmike"]
[quote="TimX5"]
I renewed the filter yesterday in the pit down at work lol
Mines not got running boards on either and from what I've seen it doesn't make a difference if they have or not , just remove the panel from underneath it's not a bad job to do .
I saw a YouTube video where you can take the metal guard off by drilling out the rivets to gain access to the filter , it's a good idea tbh and will save a little time.
[quote="TimX5"]
TimX5
[quote="7builder"]
Yeh mines facelift model
storminmike
[quote="TimX5"]
[quote="TimX5"]
LUXURY
I read something that said part of the side trim had to come off...or at least those with sidesteps. IS that not the case then when without steps.....just lots of screws?
This ins't a diesel but does it represent the panel you had to take off? The side nearest the running board intrigues, do they pass through two panels?
https://www.youtube.com/watch?v=mZ3MbtGDYzA
[quote="TimX5"]
LUXURY
TimX5
There's a separate panel/undertray which can be removed consisting of 2 no 13 mm head size bolts in the prop shaft tunnel 2 no 13 mm nuts in the same location 1 no 13 mm bolt at the front of the tray 3no 13 mm bolts concealed in recesses down the other side and 1 no 13 mm bolt hidden behind a little panel Just in front of the rear wheel and various 8 mm and 10 mm speed screws , 3no speed screws in the exhaust heat shield and I think that was it .
Tim
Tim
TimX5
storminmike
Cheers....that's a lot of screws
Now trying to eyeball all those positions you wrote down. Could I be cheeky and you put red rings round the points?
I've spotted most of them
TimX5
Jacks it is then and a whole lot of spannering an screwdrivering
If you look at the picture the tin guard can be removed if you take the 4 bolts out and grind or drill the rivets out and then you can gain access , then re-rivit the plate back on .
storminmike
[quote="TimX5"]
That idea looks tempting.... but I would pull the lot having big hands and dodgy eyesight
TimX5
[quote="TimX5"]
Any progress
[quote="TimX5"]
Any progress
