Flickering aftermarket LED brake lights with error on dash
Sanj
Re: New 2 bmw
Post by Sanj » Sun Mar 23, 2014 1:44 pm
Use my guide:))
I'm good at soldering.
Dimsum
Re: Flickering aftermarket LED brake lights with error on dash
Post by Dimsum » Sun Mar 23, 2014 1:49 pm
Sanj , I bow down to your soldering prowess..  ;)
I reckon I could manage this if I had a picture of what needed to be done..... Anyone hapoen to have one? ;)
Sent from my GT-I9300 using Tapatalk
Raj
Post by Raj » Sun Mar 23, 2014 2:10 pm
[quote="Dimsum"]
Thanks Raj
I have not soldered anything since school! Should be interesting.... I don't suppose you have a link to a guide? :)
Soldering is straight forward but otherwise just use scotch locks but make sure you reveal bare wire for the scotch lock to grip onto.
You can see the green (positive) and 2 black wires (negatives so doesn't matter which you tap into).
MAKE SURE YOU GET THE RIGHT CONNECTION OFF THE CAPACITOR (as in positive side and negative) otherwise it will get hot and go pop.
Oh and I'm a lot better at soldering than Sanj... :))
Post by X5Sport » Sun Mar 23, 2014 2:22 pm
[quote="Raj"]
Really?  What gave you that idea?  Oh I know, the fact your springs don't settle when all that metal Sanj adds gets put back in the car..... >:D
R
Sanj
Post by Sanj » Sun Mar 23, 2014 4:07 pm
That's just rude....
Ban em!!!  >:(
Post by X5Sport » Sun Mar 23, 2014 4:16 pm
:xmaskiss:
Dimsum
Post by Dimsum » Sun Mar 23, 2014 5:46 pm
Thanks for the pics Raj
I reckon I can manage that! :)
Colin
Post by Colin » Mon Mar 24, 2014 8:51 pm
I went to Maplins yesterday to get the two capacitors  but they only had one , no luck , ended up buying a PTZ camera and a 1 TB recorder , you know fools and there money are easy parted .. thats what other half says , ah well ..
05 , 30d Le Mans Blue Sport
Raj
Post by Raj » Mon Mar 24, 2014 8:54 pm
[quote="COLIN"]
Lol. At least you bought something.
Dimsum
Post by Dimsum » Mon Mar 24, 2014 9:51 pm
I need to pick up a soldering iron.
Maplins boggo soldering kit for £25 looks ok to me unless anyone else hasanother recomendation? :)
Post by X5Sport » Mon Mar 24, 2014 10:00 pm
As long as it can heat the wires it'll be fine.  If you're talking about their 40W kit that should do the job.  The smaller ones struggle to get everything hot enough.  And a bit of heat shrink sleeping to make a neater and damp proof job too..... :)
Dimsum
Post by Dimsum » Mon Mar 24, 2014 10:14 pm
Lovely, thank you..
I will get pictures up of my efforts when done.  :-[
Raj
Post by Raj » Tue Mar 25, 2014 7:12 am
[quote="Dimsum"]
THIS is the one I have and it is superb. Best soldering iron I have owned personally.
Colin
Post by Colin » Thu Feb 19, 2015 8:45 pm
Hi Raj , time flys  but i only got round to fitting those capacitors on monday , great job , no flicker now , thanks  , Colin ..
Dimsum
Post by Dimsum » Tue Oct 10, 2017 9:09 pm
I know this is a very old topic now but I’m finally getting round to sorting out the flicker on my rear lights due to the aftermarket rear clusters I fitted an age ago.
I can’t see the pics on this thread any more. Does any one have them and/or a guide for this I could use?
:D
