Mine occasionally plays up and goes -40c. Realoem only shows the sensor not where it is. Is it behind a panel or reachable without removing the bumper?
Which side is it on?
Pictures?
Air temp sensor...where is it?
storminmike
- Steamyrotter
Re: Air temp sensor...where is it?
I think it is front right corner above a plastic panel??
Please note...
Please note...
storminmike
[quote="Steamyrotter"]
Well that's a start
)..somehow I got it into my head it was inside an air duct? I've struggled to find exact info save for it;s possiibly inside or under the wing possibly forward of the wheel
It's a bit weird this fault as it went inot minus fault mode but steadilly came back to life one degree at a time. Fault I believe is open circuit so maybe it's water in the plug. The obvious downside is perhaps it triggering the webasto for no reason at start. Weekend poke around I guess, there is a hatch to the bumper area from the wheel well
Well that's a start
