Water Pump Bolts Removal ???
X5-D-Sport
Post by X5-D-Sport » Sat Feb 14, 2015 10:48 pm
E53 2004 Facelift diesel 218..
Went to replace the thermostat today....
to discover the most ridiculous bolts ever put on a vehicle... possibly to prevent over tightening I guess...
Like tapered Torx heads... sockets wont remove them...
Any one know what they are called, so I can get some special sockets to remove them ??
Greydog
Re: Water Pump Bolts Removal ???
Post by Greydog » Sun Feb 15, 2015 8:09 am
Real OEM says M7 x 38 torx screw. Maybe someone has been there before and damaged them?
X5-D-Sport
Post by X5-D-Sport » Sun Feb 15, 2015 10:04 am
Nope,
These are the original fitment...
They are best described as a tapered torx bolt... with external points... but the external splines are not parrallel... the taper off...
Ebay has lots for sale as a pump set of bolts....
But these things truly are a ridiculous concept...
X5-D-Sport
Post by X5-D-Sport » Mon Feb 16, 2015 11:07 am
What are these bolts called ?  and what will undo them...
they are approx. 6mm thread, & made of Aluminium..
eBay item number:  350613360840
Post by X5Sport » Mon Feb 16, 2015 11:49 am
They are 8mm x 32mm Aluminium 'ASA' type E-Torx bolts.  Single use only.
The ones you have listed are not recorded against the E53!  As above the OEM ones are 7x38 Torx
Usually either a Torx spline key, or E-Torx socket/spanner should do the job.  The 'E' stands for 'External'.  It could also be a Torx-Plus but they do use the same tools.
Assuming it's an M8 thread then you need an E10 socket.  M6/M7 is an E8 socket.  For some reason the E tool numbers are not the same as the T tool number!  T tools match the thread size.  T tool is the 'normal' Torx bolt where you put a key in.
They came into being to allow faster assembly times as the tool can be slightly offset to tighten them.
X5-D-Sport
Post by X5-D-Sport » Mon Feb 16, 2015 5:42 pm
Excellent Richard... Thankyou...
A trip to Halfords it is later.... Wonder what the chances are of the Halfords Monkeys having these sockets ?
Regards
GB
Post by X5Sport » Mon Feb 16, 2015 6:29 pm
Should do.  My Halfords pro socket set has them.
X5-D-Sport
Post by X5-D-Sport » Tue Feb 17, 2015 7:06 pm
So Richard,
What size do you think these Thermostat bolts actually are ?
Post by X5Sport » Tue Feb 17, 2015 10:51 pm
According to Realoem they should be Torx 7x38mm.  Should therefore be a T40 or T50 key/spline bit.  What have you found them to be?  The OEM part number is:  11517789351.
Those look like the proper 'recessed' type Torx bolts, but your picture shows external Torx which makes me wonder if your pump has been changed and a different type used?  The ones you describe should take an E8 socket.
Can you take a piccie of what is on the car?
Richard.
X5-D-Sport
Post by X5-D-Sport » Sat Feb 21, 2015 8:21 pm
Hi Richard,
These water pump bolts, are M7 x 28mm... They were a factory fitted E-Torx M7 bolt...
The E-Torx Sockets wizzed them off easily, and for the 1st time in months my Beastie has a proper temp reading now.... Hurrah...
Thanks for the help & suggestions.
Post by X5Sport » Sat Feb 21, 2015 9:37 pm
At least you solved it.  Just HTH
