transfer box chain
davey
transfer box chain
i think i need to replace the transfer box chain on my 04, 3.o x3 auto, the usual clunks, is it possible to replace the chain with the box in place, to undo the rear prop, and pull the front case off, it looks possible????????. rgds dave
- kkx5
Re: transfer box chain
...... You got new chain in your transfer...
davey
started clunking as it chenges up thro 1st and second, sounds coming from trans box, ok when cruising, puzzled, !!
- stevox5
What tyres have you got fitted and what tread depths?
These are very very sensitive with tyres , if you have non approved (star rated ) tyres fitted they tend to wind the transfer box up and clunk line hell at low speed especially when changing from first to second gear.
X5 3.0i Topaz Blue , Paddle shift steering wheel , Pioneer double din sat nav,Alpine speaker upgrade, Remap, HID's,20inch lemans alloys,lemans arch kit,Depo light kit,carbon fiber interior wrap.
davey
i,ll check the tyre sizes tomorrow, they not run flat, rgds davey
- kkx5
[quote="davey"]
Transfer is as new. You got new chain, new bearings, new seals on it. Search elsewhere. X3 are prone for rear prop shaft double joint failure (that one close to rear diff)...and the sound is, like, coming from transfer...
davey
great, thanks for that, i,ll check that as soon as it stops raining, lol, rgds davey,
davey
also, i got 235...55..18s on the front, and 255..55..18s on the back, should that make a difference??. rgds davey
That profile seems wrong. Are you sure that both axles are /55 even with different widths? Should be something like /55 on the front and /50 on the rear for those widths, or both sets completely identical. The factory sizes for 18" wheels are shown as 255/55 R18 all round, not as you state.
If they are different sizes but both /55 profile all around then you are asking for trouble due to the different rolling radius causing transmission wind-up. That will upset the transfer box and cause the noises you have.
jagr
[quote="davey"]
None of those are the correct size tyres so would assume they are not 'star' marked.
If you have the staggered setup it should be:
235/50/18 Front
255/45/18 Rear
If standard 18" they should be 235/50/18 all round.
235/50/18 Front
255/45/18 Rear
2011 BMW X3 30d M Sport
davey
so get 255...55..18s for the backs, and make all the same???
davey
ok, i double checked, 255..45..r18.rear, ....... 235..50..r18. front, ??
jagr
[quote="davey"]
I wouldn't as they would still be wrong
What make are your tyres? Do they have a 'Star' mark on them like this
davey
the backs, 255.45.18 michelins, the fronts 235.50.18 khomos, no stars, rgds davey
jagr
[quote="davey"]
The choice is yours but I would change all tyres to 'Star' marked tyres.
When I had the 18" staggered setup I had Dunlop SP01 tyres which were BMW original fitments.
