Can you identify these modules and mystery cables?
biggeek
Post by biggeek » Sat Jan 10, 2015 11:39 pm
Hello
I have recently ripped out my 16:9 headunit, MKIV Sat/Nav, DSP amp, Bluetooth module, radio module, GPS module, Alpine Dvd player, media gateway and the kitcken sink  :) which I have replaced with an Andrive AN-53. I see this as a one way trip (The harness has been cut,Gulp!) and would like to remove any other redundant units but I am not sure what these modules are. Hopefully one of you guys or  gals can help me with identify these:
I also have two rear Alpine TV screen which plug into a Alpine tme-780 module. I would like to get rid of this but the din connector looks rather small and fiddly so I will keep it until I spot some touchscreens that look like factory units.
I found some original cables and extensions on ebay so hopefully I can get this module relocated to the rear section as it was tucked under the rear carpet before and the existing power connection looks dodgy
I am also planning to add a reverse camera and have seen some post that say this plugs into the tv module but I believe that is for the factory setup. Is this correct?
The Andrive unit has an RCA connection for reverse camera so this should be fine....I actually have plugged in a composite lead and the screen goes blank when I put the car in reverse which looks like I am just missing the camera and the power connection for it. :ok:
Can you also help me identify what this cable could be used for? Looks like it taps into the reverse or brake light near the roof.
http://youtu.be/v3Dj-VnU5cw
Current: E53 4.8is, Sapphire black, Black Nappa leather, Metallic Graphite trim, 20" , "Fixed"(soon) Pano-roof, Webasto heater :ok:, 100k and counting
Recent Changes: Front & Rear suspension refresh,inc wheel bearings and hubs Arnott air bags all around, Andrive  >:( and 8 " sub.
mikem
Re: Can you identify these modules and mystery cables?
Post by mikem » Sun Jan 11, 2015 10:03 am
Black one looks identical to my Webasto remote unit - certainly that's the OEM location for fitting it.
Ubatoid
Post by Ubatoid » Sun Jan 11, 2015 3:38 pm
[quote="biggeek"]
Hello
I have recently ripped out my 16:9 headunit, MKIV Sat/Nav, DSP amp, Bluetooth module, radio module, GPS module, Alpine Dvd player, media gateway and the kitcken sink  :) which I have replaced with an Andrive AN-53. I see this as a one way trip[/quote]
Hope you kept them........
2002 4.4 cooking on gas
biggeek
Post by biggeek » Sun Jan 11, 2015 4:12 pm
[quote="Ubatoid"]
Yeah still got them I will be selling them as soon as the andrive is bedded in.
biggeek
Post by biggeek » Sun Jan 11, 2015 4:13 pm
[quote="mikem"]
Oh! interesting I will do some further research. I have a webasto unit . Thanks
