Hi guys.. Today i spent some time polishing up front headlights and upon testing couple points i noticed that car won't rev over 5000rpm in P/N. I didn't have a chance to go for a ride but guess it would behave the same in D too. Any hints as to what could be the cause of it?
Checked the obd... No errors and lights on the dash .
My Vw Golf has a Rev ,Init of 2.5 K in park And neutral. Maybe yours has a Rev limit Cohen stopped too
Had the engine warmed up enough. I'm guessing the 4.8 is like the 4.6 in that the rev counter lights go out, as the engine warms, and allows greater revs. Perhaps that restricts revs until the engine is warmed up.
[quote="pvr"]
Just curious why you would rev it in neutral that high ...
I used to enjoy revving my old one on the drive but I never went that high with the revs I just used to enjoy the rumble.
I only knew my M3 only revved to 7k in neutral from reading about it.
Current...E90 330i M Spt Blue/Black 2006
640d M Spt Blue/White 2012
Previous...
Audi TTS Black 2012
E53 X5 4.8iS Blue 2004
E92 M3 White 2009
E85 Z4 MR 2006
E61 520d 2009
E90 330d 2006
TVR Cerbera 4.5 1998
Its to protect the gearbox when in park or neutral as it heats up considerably when revving, if I remember correctly reading somewhere. Most modern auto's have a similar feature.
Because the torque converter is never inactive and neither is the input shaft. This can cause all sorts of internal issues within the various clutch, brake and planet sets and so the box needs protecting. There is no need to run an engine at those speeds in normal operation in Neutral or park.
+1 for transmission protection system. Very quick way of doing damage in the same way as towing an auto.
what damage can be done towing in an auto, just i noticed my ml has a 6400kg train weight so must be rated to 3.5t and has a mercedes detachable towbar fitted
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
I tried driving over the weekend in both auto [D] and tiptronic and simply won't go over 5k... something I noticed is that it downshifts really quickly and very odd feeling of not 'breathing' properly. I had that feeling during the student days in dad's Astra where exhaust section was so clogged that no gasses were coming out?!
I replaced vacuum hoses/CCV's and have done the scan with INPA [no issues]. Only tiny bit I noticed is that voltage is slightly off on cylinders 3 and 7... replacement coils+spark plugs will go in over the weekend to see if that's the cause but I doubt it would be. any hints?
