[quote=""BlackX5""]I think with the labour and parts it comes in at just over £400. I think the bushes are circa £40-50 each.
There is a flebay seller who sells a set of 4x Febi bushes for £90-odd quid so probably go with them. If everyone else on the forum is paying similar sort of money then I guess I will bite the bullet and get the work done.
A few garages that I called for quotes did say to me that it is never all 4 that need doing, and typically it will be 2 that are gone (the ones closer to the front of the car). What have you guys done when getting this work done, just the 2 or all 4 while the subframe was down?[/quote]
That price seems reasonable if you can't do it yourself.
It's a relativley easy job to do even with limited skills but you do have to get your hands dirty though
I borrowed Lezmtaylors bush removal tool and it took me a couple of hours to do so i saved a few hundred £££s but then i like doing my own maintenance myself (as much as my limited skills allow me anyway
I would defo change all 4 as you don't want to be paying out in the near future to replace the others aswell
The ones in the link will be fine....i'm not sure if they are the same ones i used...they may be an they have been fine
Good luck and let us know how you get on.
