I have a scanner 1.4.1 for the car but its not helping me diagnose the faulty pdc I have , ive been told a inpa module has a better chance of getting to the bottom of this.
has any one bought one of these??
http://www.ebay.co.uk/itm/BMW-USB-Diagn ... 259b2297c5
or can any one recommend a suitable device?
Steve
e53 inpa
Re: e53 inpa
Ahhh, those things...
I bought a similar item, and discovered it is simply a USB interface...
I then bought and OBD diagnostic (similar looking) with embedded BMW software that worked well.
By far the best item I got recently, and easiest to use to diagnose faults / codes is the following device from FleaBay...
It's simple, and works... £29.
If you want to program changes to your software, then more involved kit is required, and strongly recommend you learn lots before meddling with the vehicles brain....
http://www.ebay.co.uk/itm/U581-Car-Diag ... 35daf1f505
Re: e53 inpa
cheers for the reply ,
no I don't want to "mess" as such , I just got a pdc fault (all sensors are clicking but its still not working , and I got told that an inpa unit could measure the sensors and give a more accurate reading than the bmw scanner 1.4 I currently got
2002 e53 4.4 tempremental
2001 suzuki Hayabusa just for fun
Re: e53 inpa
The sensors can click but still be faulty.... the sound of the click needs to be consistent..
A unit part about to/failed will often click slightly quieter than the rest, and I've even had one click VERY loudly and be failed.
I managed to get a couple from ebay recently for about £16 for a pair.
The ones in the rear bumper are easy to remove, the front ones are a real bugger, and you need long thin fingers - lots of them....
And the hand held diagnostic tool will not detect the failure or which one... you need the full-on Laptop suite for that, and the full software diagnostic package....
I've not heard of a module failing, just the individual sensors... and mine fail two at a time generally.
The PDC sensors are NOT power washer friendly......
I killed a few sensors with my power washer...
Re: e53 inpa
[quote="Ryoken"]
Steve
Yep Ive got one of those. Nice bit of kit. It installs inpa, DIS and a host of other stuff really easily with no messing about. I had been trying to get inpa installed on my laptop for ages until I got this.
A good buy.
Steve
A good buy.
2002 4.4 cooking on gas
- sleepyfolk
Re: e53 inpa
A good buy.
What kit have you installed it on, there's seems to be a lot of negative feedback and some very happy feedback - what computer and operating system did you get it toward on?
A good buy.
Mercedes CLK 320
Audi A6 Quattro 2.4
Mercedes CLK 320
Audi A6 Quattro 2.4
Re: e53 inpa
I got mine from here, and Jimmy provides great support if you need help
http://www.cable-shack.co.uk/
Inpa is pretty safe to use as it is a diagnostic tool, not a coding tool. Its also easy to load - just watch for setting the USB port to COM1. Remember you will need a battery charger on the car while you fiddle around, otherwise you may end up with a flat battery, as you search all those nice INPA screens
