Hub Spacers 30mm on rear wheels - E53 2004 ?
Wheel hub spacers 30mm - to fit or not to fit ?
Any one had experience using these ?
I've used them over the years with my Landrover Discoveries without problems, other than a 6 monthly reset of bearings...
As the X5 rear tyres are 285 width... by putting a 30mm hub spacer, has any one noticed any major tyre wear increase or problems with geometry / handling ?
Obviously it moves the wheel/tyre centre outwards, but how fenikety is the X5 suspension on the rear ?
Penny for your thoughts ???
GB
GB
Re: Hub Spacers 30mm on rear wheels - E53 2004 ?
Hi I had 25mm spacers on the back to be able to fit E70 wheels , car ran better with the wider stance no tram lining or uneven tyre wear , the killer was the insurance as they classed it as a mod they wouldnt insure me , had to take them off .
Eventually used X6 wheels they had a lower offset & fit great !
i had 40mm on mine with no issues
current: 2016 Vw Crafter
2007 318d touring
2008 Transit sport van
1964 vw beach buggy
1988 e30 325i convertible
2007 318d touring
1964 vw beach buggy
30mm rear and 25mm fronts I was running with no issues. As they are the bolt on type they don't add quite as much stress to bearings and wheels boots etc as the extended bolt on type do.
yeh as ray says dont use the shit one with the long bolts, get the type you bolt to car then bolt wheel to them
2007 318d touring
1964 vw beach buggy
2007 318d touring
1964 vw beach buggy
i have some 20mm & 30mm hubcentric spacers for sale (proper ones),
Have you got the arch extensions ? As you need to be careful that you don't exceed the wheel arch or it will fail on the mot , plus if you get stopped by the Police they will make you change back over !
Hi Sid,
Yeah, agreed, I understand that the tyre centre looking down has to be out of view & covered by the arch.
Re previous posting -
Hi Jim, I'm interested in the 30mm pair set, just PM'd you.
regards
Grant B
regards
Grant B
Many thanks - Bamberjim.
The spacers arrived this afternoon, and will be on the car tomorrow.
Thanks again.
Grant B
Thanks again.
Grant B
