Name that hose
mattyc
Name that hose
Post by mattyc » Tue Nov 18, 2014 2:04 pm
Bit of an exhaust leak in the engine bay and I think the hose in the attached picture is the culprit. Exhaust smell coming through heater and can see some fumes coming from drivers wheel arch. Can anyone name the hose for me? It's the bendy silver section that attaches to the solid silver steel pipe.
If it's a non-exhaust hose then any pointers would be appreciated.
*Image removed as confusing
Cheers, Matt
BMX X5 2005 3.0D
Re: Name that hose
Post by X5Sport » Tue Nov 18, 2014 2:15 pm
That's one of the air conditioning lines.  It contains compressed gas so is unlikely to be the source of your problem.
The fresh air inlets are all under the top section of the scuttle - where the grilles are up top in front of the screen.
Oh, and :hi: to the Forum Matt  :)
mattyc
Re: Name that hose
Post by mattyc » Tue Nov 18, 2014 2:46 pm
Thanks Richard. OK exhaust definitely not coming out of that!
Any pointers as to where it could be coming from? Manifold, exhaust etc. sit below that pipe? Odd I can see fumes coming out of the drivers side wheel arch at idle.
Matt
BMX X5 2005 3.0D
Re: Name that hose
Post by X5Sport » Tue Nov 18, 2014 3:14 pm
The exhaust manifold is that side and there have been instances of cracked/split manifolds which would explain the smell & fumes.
mikem
Re: Name that hose
Post by mikem » Tue Nov 18, 2014 4:21 pm
Almost certainly exhaust manifold
Stevejspm
Contact:
Re: Name that hose
Post by Stevejspm » Tue Nov 18, 2014 4:45 pm
Just had my manifold changed today for that very reason. Streaming eyes after sat in traffic! All good now though & the old manifold looked cracked in about 4 places.
centurion
Re: Name that hose
Post by centurion » Tue Nov 18, 2014 5:25 pm
...is manifold crack(ing) common to all models or predominantly diesels?
davesavage257
Re: Name that hose
Post by davesavage257 » Tue Nov 18, 2014 8:04 pm
From what I've read it's a reasonably common occurrence on all BMW 6 cylinder diesels with the fabricated rather than cast manifolds.
Dave
2003 BMW X5 4.6iS Auto
2007 '57' Saab 9-3 Aero 2.0T Auto
2003 BMW X5 4.6iS Sapphire Black
mattyc
Re: Name that hose
Post by mattyc » Tue Nov 18, 2014 10:58 pm
[quote="Stevejspm"]
Dare I ask how much a new manifold and labour is? Have seen a few guides and it seems to be extensive work.
BMX X5 2005 3.0D
kkx5
Re: Name that hose
Post by kkx5 » Wed Nov 19, 2014 5:43 am
Cracked exhaust manifold on 3.0i? Very unlikely. Leaking rocker cover gasket is your problem... oil dropping on exhaust manifold.
Chrisw4266
Re: Name that hose
Post by Chrisw4266 » Wed Nov 19, 2014 11:59 am
[quote="kkx5"]
Have to agree 3.0i probably leaking rocker gasket caused by a failed ccv pressure in the rocker cover. Try removing the oil filler cap with the engine running. Should be a slight vacuum if it blows the cap off or has a massive vacuum then the ccv is shot and needs replacing.
mattyc
Re: Name that hose
Post by mattyc » Thu Nov 20, 2014 6:58 pm
3.0D folks I should have said. Cheers for the help.
BMX X5 2005 3.0D
Re: Name that hose
Post by Horizon » Thu Nov 20, 2014 7:06 pm
[quote="mattyc"]
I think the confusion is that that photo you've posted looks more like a 3.0 i engine not a diesel, I took it to be a petrol As I couldn't see the Webasco, and the engine covers looked different to my old 3.0d, more like my 530i
mikem
Re: Name that hose
Post by mikem » Thu Nov 20, 2014 7:52 pm
If it's a d I'd put money on it being the manifold (£150 for a cast replacement) and about 3hrs labour.
To confuse things, that picture above shows a petrol engine ???
mattyc
Re: Name that hose
Post by mattyc » Thu Nov 20, 2014 7:57 pm
Whoops! Sorry everyone.
BMX X5 2005 3.0D
