Are you trying to remove part number 15
http://realoem.com/bmw/showparts.do?mod ... g=31&fg=05
A slide hammer is the bmw special tool .
If you have access to TIS the repair document number is 31 12 026 . A bit of a faff to find it if it won`t link direct with that number so here is the path from the start .
Enter chassis number or vehicle type and once vehicle is identified click on "document" box at lower right of page .
Click on repair instructions which will open another menu then click on front axle then front subframe then click arrow at lower right of page .
You will now be on document 31 11 001 "replace front axle carrier" , Scroll down and click on "remove tension struts from front axle carrier" , document 31 12 080 .
click on "remove guide joint"document 31 12 026 .
Try a lot of wd40
I have a pdf and no idea how to add it to this post .
