Repairable?
IceQueenX
Re: Repairable?
[quote="535dboy"]
[quote="IceQueenX"]
Personally, I wouldn't want the hassle of a repair I'd just replace it (which I did on the old X5 when same thing occurred.)
You have too much money..............
........but agreed. I'm not a fan of them because I drive my cars hard although looking at how they are repaired I think you would have to be very unlucky for something to go wrong!!
How do they get repaired? I never trust repairs in other areas of life so a tyre and I'm definetly not going to risk it!
[quote="IceQueenX"]
- 535dboy
Re: Repairable?
It's just like a big butt plug but on the inside so the pressure keeps it there hence it can't really fail, generally.
Currently :
2012 Audi RS4 (B8)
2012 Porsche Boxster S (981)
Previously :
2008 BMW X5 3.0sd MSport
2005 BMW 535d MSport
2012 Audi RS4 (B8)
Previously :
IceQueenX
Re: Repairable?
I can only imagine the plug you speak of, but thanks for that explanation, I will bear it in mind next time hubby takes a bike apart on the drive and leaves nails out for me to drive over :'(
- 535dboy
Re: Repairable?
[quote="IceQueenX"]
Do bikes have nails?
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
IceQueenX
Re: Repairable?
[quote="535dboy"]
[quote="IceQueenX"]
) No, but his toolbox (equivalent of my handbag) does, and when he's tinkering about in there, things can fall out.
[quote="IceQueenX"]
- 535dboy
Re: Repairable?
[quote="IceQueenX"]
[quote="535dboy"]
[quote="IceQueenX"]
Then clearly you need to get him to keep his tools under control
[quote="535dboy"]
[quote="IceQueenX"]
Currently :
2012 Audi RS4 (B8)
Previously :
2012 Audi RS4 (B8)
Previously :
Re: Repairable?
My wife would never let me tinker in her handbags!!
IceQueenX
Re: Repairable?
[quote="535dboy"]
[quote="IceQueenX"]
[quote="535dboy"]
[quote="IceQueenX"]
The tools are not the problem, it's the bits and bobs!
[quote="IceQueenX"]
[quote="535dboy"]
[quote="IceQueenX"]
IceQueenX
Re: Repairable?
Aaah, maybe the forumites could club together and buy you your very own to tinker with
Re: Repairable?
I gave a 'man bag' in black already, and one is enough! It's usually full of spare clothes and the other 'items' a 19-month old will likely need at inopportune moments!
RenoHuskerDu
Re: Repairable?
I would not repair it, unless I was waiting for the white van man to deliver replacement tyres. I had the same problem, same spot, and did exactly that. I plugged it myself and ordered two new tyres. I only drove on it for 3 days and was a tad nervous. But the alternative was to drive our Polo or Disco ... grim indeed once you've been spoiled by an E70.
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
pcdee
Re: Repairable?
Sorry for the late reply. .....
Update. ... they fixed it and recommended a new tyre.
Just using it for town driving going no more than 30 till my new tyre arrives
X5 E70 3.0D SE
rj1986
Re: Repairable?
[quote="IceQueenX"]
[quote="535dboy"]
[quote="IceQueenX"]
They are like a mushroom, with a very thick neck.
They bore out a clean hole (ooh-eer missus), compress the neck of the mushroom in a metal tube and pull the tube through (or push the mushroom part in - depending if the tyre stays on)
They then pull the tube off, the neck expands and plugs the outer whole. Then when the air goes in, the mushroom part expands out and is flattened by the pressure, plugging it fully.
I've used these before and they are remarkable reliable when i was on a shoot and we didn't have time to go find a kwik fit.
http://www.stopngo.com/pocket-tire-plugger-for-all-tubeless-tires/
The pressure stops air escaping, and the rest of the tread takes the contact with the road so the repaired area isn't touched.
Some garages use patches which are like a massive plaster that stays on the inside, but need to be on the "flat" area of the tyre to stay put.
[quote="535dboy"]
[quote="IceQueenX"]
IceQueenX
Re: Repairable?
Thanks for that very concise explanation, it does sound extremely safe I must admit! Maybe I'll save some pennies if there is a next time! Prefer the mushroom option to the giant plaster
IQ
IQ
