Idrive oil level too high?
celica
Post by celica » Fri Nov 07, 2014 9:22 pm
Just had an oil change at an Indy, well a week ago
Got playing with the idrive and noticed the idrive oil level status is too high
3.0sd, so checked the dipstick after a short drive so car is warm and level
The oil is probably coming to the top of the "max" wording plastic part on dip stick
Is this too high, or a start of another issue
Did some quick reading and some have had oil sensor changed, idrive reset, one thread even talked about fuel, dpf issue etc.
Hoping to swing past the Indy if they are open tomorrow
Re: Idrive oil level too high?
Post by X5Sport » Fri Nov 07, 2014 10:03 pm
I had this on my X6 and the Dealer told me off.....and then apologised when I told them the only people adding oil were them!  Seems to be a common issue.  I haven't had anything replaced though.
celica
Post by celica » Fri Nov 07, 2014 10:23 pm
Did you/ dealer  take some out?
Did it fix the message on idrive?
celica
Post by celica » Sat Nov 08, 2014 10:53 am
Went to the Indy
He checked the dipstick
It was a touch over the max line, and sensitive sensor
Could have drained some out but its near perfect really
Nice to have the reassurance
RenoHuskerDu
Post by RenoHuskerDu » Sat Nov 08, 2014 11:16 am
Without being a tad alarmist, one must always be aware of a risk with diesel motors. If a leaking injector is introducing too much fuel into a cylinder, that fuel will accumulate with the motor oil in the crankcase, and elevated oil level will be the first symptom you see. You may first hear a rough idle.
It does not sound like this is your case.
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
celica
Post by celica » Sat Nov 08, 2014 12:19 pm
I like to be alarmist, better to be safe than sorry
The Indy just changed my oil and I know how much they put in as I supplied 2x4L oil
One had some left so I know it's not too much
But the above is good to know
Post by X5Sport » Sat Nov 08, 2014 8:59 pm
[quote="celica"]
No message in the iDrive.  They found it during a 'safety check' when my tyres were swapped from Summer to Winter.  And yes they took a little out.
With regard to the fuel in the oil, you would also see your mpg plummet as the fuel consumption would rise as well.  It needs a lot of fuel to get through given the minute amounts used per cycle and if (like me) you are diligent in checking you would notice the change in the oil in good time.
RenoHuskerDu
Post by RenoHuskerDu » Sun Nov 09, 2014 6:02 pm
This warning was passed to me by my cousin the VW mechanic, in an effort to talk me out of a Q7 or A6.
It worked.
To be fair, I had heard of the risk before. Supposedly, it happens to our cars too, but rather more rare than on VWs.
celica
Post by celica » Sun Nov 09, 2014 9:03 pm
Bristol to birm run today and the usual 29-30mpg I see on motorways today
So didn't see fuel consumption plummet
damian777
Post by damian777 » Sun Nov 09, 2014 11:15 pm
Hello Celia/ Richard and  all,
Well  i've had that same  "Oil Level to high "  on the I Drive  fault displayed as well..  I have checked the level on the  dipstick and it appears  at max  but not above.  .Tomorrow  morning  the cars into main dealer  for service  at 20,000 miles , had the  fault displayed twice in the last few months, and its an oil service tomorrow ( 10 Nov ) so i will mention it to the service guys.  I will post their  comments here on wednesday !
PS  Ive also  been told this week by the main dealer  when i telephoned to book the car in for a service ,i have a recall notice  on my prop shaft ( all  2011 X5 4D )  anyone know of this  issue.?  They will inspect and re book the  vehicle if replacement item required under  warranty .
D
Past Bm 's    M 6 ( 1986 ) ( all time favourite in 1980s  so rare  !),  M3x  2 .  540 , 3 series  loads ... X 5  x 3 .   , 2006 X 5  M Sport,   2009 D M sport in white  , Now  2011 X 5  4 D M Sport in white !
Ivory leather piped in black, Panoramic roof, camera x3 .
Post by X5Sport » Mon Nov 10, 2014 9:09 am
The propshaft issue is real and is due to faulty construction leading to excessive backlash and the potential to break one or more of the bolts leading to the shaft detaching!  The Dealer will check the amount of play and replace the shaft if there is a problem.
It only affected a few hundred cars....mine was done months ago.....and was being done at the time of the next service, though you could insist it was done earlier (which I did).
damian777
Post by damian777 » Mon Nov 10, 2014 1:18 pm
Hi Richard
Back from main dealer early, inspection service  and prop shaft check all completed, like you said for excess play.  No play so all ok but the cars only done 20,000  so  i wouldn't expect wear on anything like a Propshaft .
As i drove out of the forecourt " Oil level too High " picture came up as i checked  the dealer had reset service interval date/mileage on the i drive system., so i did a 180 and went back in. They reset it and said it was possibly due to the car being on a ramp. ( and my drive has  a slight downhill slope so when i start it  in the morning may  shift the oil in the  sump to the rear. ? )  They said it would re set itself after a few miles driving  which it seems  to have done on my way home from the dealer, 15 miles. :'(
Could it really be that the i sensor for oil level is just too sensitive re car incline at start up ?
D
Post by X5Sport » Mon Nov 10, 2014 6:13 pm
Glad it's sorted.  My propshaft was replaced with 15k on the clock due to play.  Very quick job to change it.  Under 30 mins.
Nothing worse than false alarms!!
