bm54 unit upgraded
Ryoken
bm54 unit upgraded
Post by Ryoken » Thu Oct 23, 2014 4:02 pm
well I bit the bullet and got my bm54 unit upgraded and repaired , from Baris at carphonics
2 days turn around ,
I now have decent amps , aux on head unit , and music streaming ,
very happy :)
2002 e53 4.4  tempremental
2001 suzuki Hayabusa just for fun
storminmike
Re: bm54 unit upgraded
Post by storminmike » Thu Oct 23, 2014 8:49 pm
[quote="Ryoken"]
very happy :)
Tell us more....the wife's X5 is just a CD up front...no screen...what wonders can be done and for how much?
Ryoken
Post by Ryoken » Fri Oct 24, 2014 4:58 am
well i got mine repaired as it had missing speakers, and the ones it had crackled, then i had a stage 2 amp upgrade,  firmware upgrade, which adds aux to headunit, then music streaming,  all for 209 squids
heres the web page
http://www.carphonics.co.uk/bm54upgrades.htm
ChrisLux
Post by ChrisLux » Fri Oct 24, 2014 12:37 pm
I've just bought a standard 2/h BM54 to send away and have upgraded.
Seen lotsa reviews on M3Cutters and they all rave about Baris.
cooa99
Post by cooa99 » Mon Oct 27, 2014 11:35 am
I had mine upgraded a while ago as well. A shame i did not know my previous one could be fixed before I ended up buying a new unit from BMW :(
My only issue is that the newly added Bluetooth to the BM54 for streaming does not always connect.
However I  found that threading the cable to be visible the sitting cabin or switching off the stock Bluetooth helps.
Current Cars BMW 2005 X5 3.0d ;  Golf 2003 1.9 TDI for the High Miles Journey to work
centurion
Post by centurion » Mon Oct 27, 2014 2:15 pm
correct me if i'm wrong but AUX is enabled but hidden and as soon as you connect some form of cable/lead (e.g. iPhone/iPad adapter for instance) it is shown in the sat/nav, right?
Ryoken
Post by Ryoken » Mon Oct 27, 2014 8:55 pm
dunno on that one,  I know mines working no probs at all, no probs connecting to streaming bit
Moments
Post by Moments » Wed Oct 29, 2014 8:50 am
+1 for Baris. Best £99 spent on my BM54, the audio is way better (and all speakers work!)
Regarding aux: the menu option appears when the physical cable is connected to the audio. The physical cable has a resistor (300kohm if I recall correctly) which is between two of the wires: when the audio unit 'sees' this resistance it enables "Aux" as a menu option.
For my E53 I bought the cable from BMW, as it was under warranty at the time. For my M3 I went to Maplin for the bits and made it for about £5, dead easy to install.
Top tip for the nav unit with Aux newly installed: the volume is extremely low. Use buttons 1-6 to change this :-)
ChrisLux
Post by ChrisLux » Wed Nov 05, 2014 2:11 pm
[quote="Moments"]
I've got an AUX cable I bought on another forum, and it's always worked well, EXCEPT that the volume output
is far less than the other sources Radio/CD/Tape (yes I still use it!!)
Are you saying that you can adjust the output volume on AUX by pushing buttons 1-6 (the ones that change the CD's in the charger and radio stations etc) ??
Is 1 the lowest and 6 the highest volume setting in this case ??
chrisn7
Post by chrisn7 » Fri Nov 07, 2014 1:46 pm
[quote="storminmike"]
[quote="Ryoken"]
very happy :)
[/quote] Nothing as far as I know. The MID units don't even have the separate BM54 module in the boot-its all self contained in the Head unit in the dash
Moments
Post by Moments » Tue Nov 25, 2014 11:21 pm
ChrisLux - sorry for the late reply but 'yes' to your question. With Aux enabled use buttons 1 through 6 to vary the volume.
I think 1, lowest, is enabled by default
ChrisLux
Post by ChrisLux » Wed Nov 26, 2014 1:25 pm
[quote="Moments"]
Cheers  :D
centurion
Post by centurion » Fri Nov 28, 2014 4:10 pm
[quote="chrisn7"]
[quote="Ryoken"]
very happy :)
Hi.., is this applicable to all facelift models with nav screen so to speak?
chelsea
Post by chelsea » Fri Nov 28, 2014 9:12 pm
sorry for maybe bombing the post??
I am finding the stereo a tad crap to be honest considering the car was supposed to be top of the class at the time, I think the actual head unit may be ok if the speakers are upgraded etc?
I'm looking at replacing all the speakers in the car and adding a subwoofer somewhere out of sight (not a massive box in boot type!)
Q's are.........does sending the original head unit away for upgrade (what does it do??) make loads of difference and if it does and I did then what speaker choice have those that have done this suggest I go for??
I have a budget of maybe up to £600 no more.
thanks for any input on this  :)
E53 X5 SE 2005
Lotus Elise S1
Aprillia Caponord
2 Caravans.
