2004 3.0 D SPORT Battery dead
Benarchard
Post by Benarchard » Tue Nov 04, 2014 10:11 pm
Guys any verdict on whats a decent battery to replace with?  Halfords own brand OK or should I go premium..
Re: 2004 3.0 D SPORT Battery dead
Post by X5Sport » Tue Nov 04, 2014 10:35 pm
Bosch S5 or S6.  Eurocarparts are offering discounts on batteries at present.  You need an '019' fitment, and make sure you vent it!
Post by Horizon » Tue Nov 04, 2014 10:54 pm
I fitted a Bosch S5 019, 100ah. Around £100, or even cheaper if you shop around check ECP.
Smeeagain
Post by Smeeagain » Fri Nov 07, 2014 10:26 pm
Definitely a bosch - they come with five year guarantee so keep the paperwork!
Richard what's the difference between the S5 and S6?
shadrack
Post by shadrack » Fri Nov 07, 2014 10:28 pm
the number is usually the years warrenty
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
Smeeagain
Post by Smeeagain » Sun Nov 23, 2014 3:38 pm
What is the reason for specifying the 019 fitment (what is it what does it do?)
Also I've heard of a 130ah version too I think?
Post by X5Sport » Sun Nov 23, 2014 4:43 pm
019 is the physical shape/size of the battery.  Each battery type is made to one of a number of fitments  which all manufacturers use.  Otherwise called a 'form factor'.  For battery ratings, the standard hourly is around 90-110Ah with a Cold Crank Amperage (CCA) - maximum cold starting current draw - of around 830A.  Petrol engined versions are slightly lower rated as they need less cranking to start due to lower compression and the lack of Glowplugs - which draw a lot!
If you go too high in terms of hourly rating then your alternator may struggle to fully charge the battery as the alternator and battery are matched within a range.  130Ah is on the upper limit I suspect.  It just means it will produce output for longer, but needs a bigger charger to keep it topped up.
Smeeagain
Post by Smeeagain » Sun Nov 23, 2014 5:24 pm
So for the avoidance of confusion this would be the correct battery (not recommending the site or the price just enquiring about the spec)?
http://www.autopointcarparts.co.uk/inde ... s5013.html
Post by X5Sport » Sun Nov 23, 2014 7:53 pm
The picture is wrong, but the description looks right.
It actually looks like this.
When you replace it, make sure you keep and reconnect the vent hose and put a plug in the other vent (they're holes in the side and plugs are moulded into the battery top.  Just snap off and insert.) so you vent gases overboard.
