Tyre pressur monitoring
allforus
Post by allforus » Wed Oct 08, 2014 8:33 pm
Hi gents any of you had a look at the tpm  screen does it just display green or does it show tyre pressures etc
X5 F15 30d msport
5 series g31 20d
Dr C
Re: Tyre pressur monitoring
Post by Dr C » Thu Oct 09, 2014 7:06 am
Pretty sure mine is just green with no pressures on it. Is yours the same? I've never had issues with the tyre pressure on the X5, but I've got it on my Golf too and it is the same there, no actual pressures displayed - it just beeps and flashes up a message in the dash if the pressure drops. I then just put air in and reset the TPMS. I would assume it's the same for the X5.
Current:
F15 X5 M50d
Mark 7 VW Golf GTD
sramsay
Post by sramsay » Thu Oct 09, 2014 5:40 pm
My old Touareg used to show the pressures for each tyre. Was quite handy.
bobgolden
Post by bobgolden » Thu Oct 09, 2014 7:51 pm
Mine shows pressures and you can select the display unit too (bar or PSI). Don't bother with PSI though as the door card only show inflation pressure in bar !
X5 xDrive 30D M Sport (F15)
allforus
Post by allforus » Thu Oct 09, 2014 8:51 pm
Think the later f15 have the whole pressure  thing but the early ones only have the green display
X5 F15 30d msport
5 series g31 20d
Dr C
Post by Dr C » Fri Oct 10, 2014 8:05 am
Makes sense re. early ones...I picked mine up on launch night last November. Getting a bit peed off hearing about all these wee improvements introduced in the months after launch; I heard the instrument cluster is all LCD/digital (like the Range Rover) as standard now? That one really annoyed me!
Current:
F15 X5 M50d
Mark 7 VW Golf GTD
Post by X5Sport » Fri Oct 10, 2014 9:20 am
Same thing happened with the E70 and E71.  New iDrives, new functions, new Comms systems all within a few months.  Then new versions that could not be retrofitted despite BMW saying they would be and then changing their minds.
I guess it's how all manufacturers sell cars.
kenniff
Post by kenniff » Fri Oct 10, 2014 9:58 am
[quote="Dr C"]
On the plus side, we had ours first :)
Current: M50i arctic grey (G05)
Previous: RRS P400 HST, F15 M50d,F15 30d Msport, E70 35d Msport, 530i, Boxster, 330Ci Sport Vectra GSi, Chevrolet Lumina, Vxl Astras
It'll be allright in the end. If it isn't allright it isn't the end
allforus
Post by allforus » Fri Oct 10, 2014 8:35 pm
Yes I agree even noticed that Bhp is up on the 30 d a tiny bit but the gearbox change which is coming takes a step further
X5 F15 30d msport
5 series g31 20d
bobgolden
Post by bobgolden » Sun Oct 12, 2014 12:04 am
I think the LCD dash was available if you specified the HUD at the time mine was ordered in MAR 2014.  The latest version has it as an option without the HUD I believe.  There have been a few reports of the displays going blank on the RRS so at least with an old fashioned analogue system you will know how fast you're going to hit the tree when the techie systems fail.
