pre wired for Bluetooth?
Benarchard
Post by Benarchard » Sat Sep 27, 2014 1:13 pm
So I have all the buttons on steering wheel and a mic in roof. However nothing in the arm rest when I took it apart. Also I looked for loom and connectors in the boot. I found what I think is Bluetooth antenna plug purple and black. I also found a small white 2/4 pin connector and a blue connector behind cd changer but I am still not sure if these are all I need to plug and play... Any suggestions??
Steamyrotter
Re: pre wired for Bluetooth?
Post by Steamyrotter » Sun Sep 28, 2014 9:39 pm
Look for silver box on the left rear poking up through floor (behind CD cover)
It is set at an angle, and only a small portion poking through.
Of its there then you have it, if not then you may be able to retro fit
Search for ULF on here, there is a picture of it which makes more sense!!
Please note...
jason1872
Post by jason1872 » Mon Sep 29, 2014 5:02 pm
i'm in the middle of doing this but don't have the purple and cream fakra cable that runs from the antenna to the bluetooth module,anyone got a spare?
