bmw scanner v 1.4.0
bmw scanner v 1.4.0
Hi all
new scanner arrived today and no instrucions HELP!
I have windows 7 OS
So do i plug the scanner into the car and does it do the rest?
I haven't touched the car yet
I've loaded the little disc that came with it but it says device drivers are not installed
the version on the disc is: P.A soft v1.4.0 2007 Date modified 22/05/2009 and the size of the file is 3.9MB
Thanks in advance
stuart
I have windows 7 OS
Thanks in advance
stuart
Re: bmw scanner v 1.4.0
yes, have disc in your cd drive on laptop.
insert the black box into car socket, connect lead to computer, turn ignition on .
then windows should say new device detected... and let it look on the cd to load the driver.
Not as easy as that I'm afraid. You will need to get the drivers off the disc, not as easy as this sounds either!! What you have to do is copy the drivers and save them in a new folder on your desktop. When you open the dashboard it will say "no drivers installed" It will give you an option to browse. Just pick your new folder you have just created and Bobs your uncle
Hope this helps?
Graham
Hope this helps?
Graham
Hi graham
Done as you said and opened the sys file with pa soft scanner
Now the driver light is green and the adapter is yellow
is this right do you get tis if the adapter isn't connected
if so i'll try it on the car tommorrow
regards
stuart
regards
stuart
Yes this sounds right. Plug it into your car, it will ask you to put ignition on and confirm. Once you do this near the bottom on the right hand side is a scan button. Press this and it will scan all your car files.
Graham
Graham
thanks for that
I'll give it a go and let you know
Did you enable tv in motion
If i've got problems/questions can i pm you
regards
stuart
thanks for that
regards
stuart
Hi all
it won't work in the car
In my device manager the scanner is under unknown devices and not the usb
I seem to have the ini file missing
can you email me your driver files graham and i'll try that
I live in stockton on tees are you near to me
regards
stuart
regards
stuart
Quick Update
got the drivers working on my PC upstairs and the scanner is in my usb of the device manager
now when you click on the logo it says harware error
does this mean the scanner is faulty
regards
regards
[quote=""sturach""]Hi all
regards
stuart[/quote]
Hi sorry stuart yes I'm in Sunderland. If you want to have a drive up tomorrow I'll sort it for you mate. It will have to be in the morning though? PM me and I'll send you my number.
Graham
regards
stuart[/quote]
Graham
Hi Graham
I think the scanner is faulty from it saying hardware error
do you think it's just a driver problem
regards
stuart
regards
stuart
i honestly dont know? are you getting the dashboard up?
Hi graham
where did you get your scanner + software from
Mine is off ebay
I'm also in communications with the seller so i'm probaly going to get a refund
I only wanted it to config the car with aux heating, tv in motion, alarm bleeps setup
regards
stuart
Mine is off ebay
regards
stuart
Got mine off Ebay, I can do all that for you my friend.
i've pm you can you send your number
Did you used to have a m5 if so i think my mate bought it off you
regards
stuart
regards
stuart
that would be Ian... the copper!! nice guy
