[quote=""fenj66""]ok, done the scan and found the error "front right unit". i dont know if that means the front right corner or inner sensor.
but alas, too cold to be fiddling with it at the moment, but when its a little better, are they easy to get to to hopefully dry out?
cheers..[/quote]
Glad you have found the culprit
![Thumbs Up :thumbsup:](./images/smilies/smilie_thumbsup.gif)
just a thought before you go taking off the bumper etc ...when it's possible try the hairdyer method of pvr as it could just be moisture with the cold spell.
If it is caput you will need the 90 degree type sensor as the two front corners are different to all the others(they are straight ones).
When i did my front left one i tried drying it out first (see pic) but it was fubar so i replaced it and they worked fine.But now thay are all over the shop and all i get is a constant beep even when going forward after reversing
![Surprised :o](./images/smilies/shocked.gif)
which is why i think it's the module
good luck
here's how to dry the sukers out
![Very Happy :D](./images/smilies/biggrin.gif)
and here's what a corner one looks like...
![Image](http://i420.photobucket.com/albums/pp288/mitchnixon/e53%20bumper%20removal/100_0342.jpg)
