How to defeat the automatic steering wheel dance?
RenoHuskerDu
Post by RenoHuskerDu » Mon Sep 01, 2014 8:55 pm
I don't need the steering wheel to move when I get in and out.  Others surely find it useful but in my case it's just wasted wear and tear for the car.  Same goes for the power seat adjustment. I have it set just where I want it, lumbar and all.
I looked around in I-drive but found no way to turn that feature off.  Anybody BTDT? (been there, done that)
Reno: Alsace, France = only 30 minutes to Germany der Vaterland!
2011 E70 40d well kitted from the factory, RaceChip 375hp
2005 E53 3.0d, manual gearbox, sport susp, RaceChip 278hp
Sanj
Re: How to defeat the automatic steering wheel dance?
Post by Sanj » Mon Sep 01, 2014 9:56 pm
Don't own one, but is there a dedicated fuse you can remove?
Post by X5Sport » Tue Sep 02, 2014 10:48 am
The seat and wheel both store in key memory so as long as you use the same key then it should not move.  The steering wheel position is part of the easy access function so as Sanj says you'll need to find the fuse although it's likely to be a shared circuit.
Not seen a write up anywhere of said system being switched off, but it might be a programmable function in the main software rather than the iDrive.
RenoHuskerDu
Post by RenoHuskerDu » Tue Sep 02, 2014 11:14 am
Do we have a door into that programming? My background is rdbms so I can code a bit.
Post by X5Sport » Tue Sep 02, 2014 12:45 pm
Have a look at bmwcoders on the web.  They're heavily into the coding of cars and will be able to help with the systems/software/hardware you might need.
Nine468
Post by Nine468 » Tue Sep 02, 2014 1:35 pm
Ive got exactly the same problem.
I dont need the wheel to retract etc everytime i remove the key... ::)
And ive asked the same question before with no success...
So ill be watching this closely....
Dave W.
BMW G05 X5 40D
RenoHuskerDu
Post by RenoHuskerDu » Wed Sep 17, 2014 2:21 pm
I just signed up for bwmcoders and posed the question there.  Looks like a boatload of good info on the site!
Thanks for the tip.
X5-D-Sport
Post by X5-D-Sport » Sun Sep 21, 2014 2:14 pm
you could just drop the steering wheel under-panel & disconnect the connector plug to the mechanism once its in the right place & it will never move again..... BUT, may throw up a warning of a failure on the instrument cluster instead.....
Personally, I like the quirkiness of it & ignor it...
