# ERRORS DETAILS - DTC(hex)/PARAM(hex)
ABS -> 5A/D2 - Temporary system deactivation
SRS -> Shadow-memory:
06/40 - Side airbag, front right door, resistance too high
IKE -> BD/50 - Electronic braking-force distribution
PDC -> 22/C6 - Acoustic generator, front, off
BMBT -> 16/21 - EEPROM Checksum does not match with programmed value
LRA -> Shadow-memory:
00/00 - Terminal 30
# SCAN END
any got any pointers ??
Steve
did , my first scan on the obd2
Ryoken
2002 e53 4.4 tempremental
2001 suzuki Hayabusa just for fun
Re: did , my first scan on the obd2
First edit your VIN out!!
SRS: The airbag one simply means the system is not happy about one airbag connection. Could just be bad. Air bag may not fire if needed in anger.
PDC: Looks self explanatory. Front parking sensors look to be switched off. Had any trouble with them?
BMBT: on board monitor head may have been changed in the past for a new/used replacement. The system expects to see one number but it's getting another one so it doesn't recognise it.
Never anthropomorphise computers. They hate that.- Sanj
Mwahahahaaaa, I have his VIN! >:D
Ryoken
deleted everything apart from codes
i know the drivers door cards been removed at some point, so that could be air bag ( window regulator maybe ?)
pdc..... doesnt work, had a rear drivers out a bit ago which got replaced, all sensors work now but, still get flashing bdc and long beeeeep.
bmbt. could be i updated the firmware on the sat nav , could be that?..
dunno
Steve
dunno
Steve
It's a possible with the door card and the air bag plug isn't fully home.
PDC obviously still needs investigation. If the sensors are all clicking then it could be a module issue, or a wiring fault.
BMBT, no the software change is in the boot so that shouldn't affect the head as it's only taking a video stream from the nav computer. It may be that at some point the head failed and was replaced?
