My new(ish) E83 Issues
Gaff
Post by Gaff » Fri Aug 08, 2014 11:26 pm
Hey, so I purchased an X3, E83 M Sport. I knew what My X5 offered, so went with the same 3.0d. Wanted to Down size a little, so thought this would be perfect. However, the guy I bought it from replaced the head unit with a Sony deck, which plays radio fine, but although connected, no bluetooth sound, neither does it play my CDs. :(  It does have some "massive" sound coming from it when it does play, sure it's got a sub hidden somewhere:)
The Gear box seems to be unwilling to gear down when stopped at the lights, and only when I put my foot on the gas does it do so with a shudder and then engage one with a jerk.
Thanks to Richard, found out about PMW Chelmsford. I'll take it to them and have the Swirl flap confirmed, replaced with blanking plate, and EGR cleaned.
Oh, and the Run flat indicator keeps coming on, hold reset lasts may a week.
So any advice on the above? Also, what else should I consider doing, as I think I will keep this one for a while.
Thanks peops. I'll load some pics once I have got some time to detail her.
Current:
E83 X3
E90 MSport
'56 LeMans Exclusive Edition X5
Honda Civic 1.6
Previous:
Toyota Previa 2.0 D4D
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
jagr
Re: My new(ish) E83 Issues
Post by jagr » Sat Aug 09, 2014 2:26 am
Do the swirl flaps yourself, it will cost you less than £30.
Gearbox could be you need an update as my mates old X3 needed one when his auto box had a mind of its own.
Do you have the 'Star' rated tyres?
Check/Change your fuel filter as my '56 and my mates '05 both have bmw service history but when changed mine had '06 and my mates had '05 stamped on them.
Change your oil separator for the vortex type.
Check your washer bottle as the pumps get gunged up and operate poorly.
Check your rear carpet behind drivers seat as the washer pipe comes apart and fills the car with water.
2011 BMW X3 30d M Sport
Gaff
Post by Gaff » Sat Aug 09, 2014 8:50 am
Been thinking about doing the SF myself, but would the car need to be programmed to let it know it's running without?
I would like to change the oil and get software updated for the Gearbox. I am in Essex, anyone with a recommended Gearbox Mech? Read some forums, lots are against messing with a gearbox.
Star tyres? Guessing you mean branded. Will they are all new, that's the good news. The bad news is they are Michellin in the rear, front right's Pirelli, and the left is a brand i have NEVER heard before  LOL :()
The other stuff I'll get to, but the SF is priority.
Thanks Jagr!
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
Post by X5Sport » Sat Aug 09, 2014 9:39 am
If you leave the flap controller in place (as I did on the E46) then the car thinks the flaps are present so no coding needed.  I think they're only used at idle anyway.
Are your tyre pressures OK?  '*' marked tyres are the 'right' ones to fit as they are made to fit on any BMW.  Sometimes the 4WD system can get uppity about having either the 'wrong' tyres or if there is a lot of wear on a particular wheel.  Given you have three different types, that could be the issue.
It's only a technicality really, but there have been issues reported by some who have not used '*' marked tyres with either the pressure warning coming on, or even problems with the 4WD/diffs/transfer boxes.  It seems the BMW transmission can be sensitive to this.
The ABS checks the rotation rates so one rolling at a different rate (as it would if the pressure or rolling radius was different) will bring the light on.
Gaff
Post by Gaff » Thu Aug 14, 2014 10:56 am
Thanks guys, So I have booked the X3 into PMW for a full check over, EGR and Swirls. That gearbox shudders is beginning to worry, so willget them to run a  full diag. Hoping it all goes well, will let you know what they're like, and how I get on.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
Gaff
Post by Gaff » Sat Aug 23, 2014 2:23 pm
So PMW were good. The guys did a complete inspection of the X3. They were picky to the point of door rubbers needed replacement, rear washer not working but apparent leak into trim of veh (I've not used yet) and flat spot on nsr tyre.
Now I come to the gurus on here asking for recommended parts. I like Bosch, and they appear to be good quality. Can you help...
Glow plugs - Bosch £12 per. I think I will replace all at that price. But only GP 4 faulty.
Swirl flaps recommended.
Transmission oil and filter replacement, as well as Transfer box oil replacement.
Engine thermostat and EGR thermostat along with full anti-freeze.
These are the main changes required.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
jagr
Post by jagr » Sat Aug 23, 2014 3:27 pm
[quote="Gaff"]
rear washer not working but apparent leak into trim of vehicle (I've not used yet).
Common fault that is a pain to fix as you have to remove the drivers seat and lift the carpet. The rear washer pipe gets separated there and needs to be reconnected. The dealer I bought mine from used heat shrink as well for good measure.
[quote="Gaff"]
If needed change when doing swirl flaps. Bosch are good quality.
[quote="Gaff"]
I used these on mine:
http://www.ebay.co.uk/itm/4X-22MM-BMW-D ... true&rt=nc
[quote="Gaff"]
Use recommended BMW oils as they are picky items on the X3
[quote="Gaff"]
Haven't done mine yet
Gaff
Post by Gaff » Sat Aug 23, 2014 3:36 pm
Thanks Jagr. Eurocarparts got a 50% off at the minute, headed there Tues (Mon Bank hol:()
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
Gaff
Post by Gaff » Sat Aug 23, 2014 3:44 pm
With regards to the Glow plugs, only one was faulty, do you recommend changing all 6?
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
jagr
Post by jagr » Sat Aug 23, 2014 3:53 pm
[quote="Gaff"]
If doing it yourself I would probably just change the one. If you are paying someone change them all.
Gaff
Post by Gaff » Sat Oct 25, 2014 5:28 am
Morning all, sorry about not replying sooner. Have been caning the overtime to pay for the jobs above. Anyways, as my DIY skills are limited, not to mention a plier and flat head screw driver can only go that far... i decided to go with PMW Chelmsford.
Review: Customer service top. The guy at the front desk great - Talk the talk. But I wasn't able to speak to the guy who actually worked on my X3. all the jobs were done, and I have to rely on their professionalism that it was all done to a high standard  :(
In total cost me £1066, but all above was done. The gearbox is fantastic now, really smooth. Don't notice any performance issue with the swirl flaps done, although i must admit economy for a diesel is something left to be desired.
I would say that the 3.0D in my E53 was by far a strong performer, in power and economy. DOn't know why, though a lighter X3 would be better, even if not by a little. Any ideas?
last job to do - front lights. They are yellow  halogen i think. I want to upgrade, not necessarily to Xenons, but HIDs. Any recommendations?
Thanks guys.
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
Post by X5Sport » Sat Oct 25, 2014 10:00 am
3.0d E83 I drove was pretty quick.  Not sure on the power, but it might be the same as our E46 Conv so is 204bhp rather than the 218 in the E53.  I de flapped the E46 in the summer and have not noticed any significant performance change.  Being a conv it weighs nearly 1800kgs and still goes like a rocket.
Xenons/HIDS is an interchangeable term.  You can get HID lookalikes in normal bulbs from people like Philips or Osram that are pretty good and at least the lighting pattern will be OK as the filaments are correctly positioned.
Something like 'Nightbreaker' or 'Xtreme Vision' would do the job.  I think there are HID lookalike versions.  Places like Powerbulbs are a good source.  they won't be a perfect match though.
Gaff
Post by Gaff » Mon Nov 03, 2014 7:26 pm
OK, so I have been searching for the best Oil to use, I've come back with
Castrol Engine Oil (Edge 0W-30 With Titanium FST Fully Synthetic................ or
Castrol Engine Oil (Magnatec 5w30 - C3 Spec................??? Anyone with experience?
As for The lights, going to get the HID COnv kit from Hids Direct for the Dipped, Phillips Xtreme 130+ for Mains. And final for this car will be a Chip box - if money allows. I want a box, that I can remove when time to sell on. I, by recommendation, found http://www.tdi-tuning.co.uk/ to be helpful. SO, lets see what comes of it.
AS always, thanks!
Gaff
Current:
E83 X3
E90 MSport
Honda Civic 1.6
Previous:
Vauxhall Astra 1.6
E36 BMW 1.8 4 door
1.5 Honda Civic
Post by Horizon » Mon Nov 03, 2014 7:42 pm
Someone put up a link up regardingfor nightbreakers ( on another forum ) being reduced to £18 at Euro car parts this week :)
shadrack
Post by shadrack » Mon Nov 03, 2014 8:29 pm
them odd front tyres will do an x3 no favours, i had a major gearbox fault on my rrs which turned out to be odd make front tyres on front axle and rrs arnt known for it like the x3 is
current: 2016 Vw Crafter
              2007 318d touring
              2008 Transit sport van
              1964 vw beach buggy
              1988 e30 325i convertible
