is it possible
Smeeagain
is it possible
Post by Smeeagain » Sun Jul 27, 2014 5:35 pm
on a 2004 E53 3.0 D to switch off the interior boot light when the tailgate is open, without pulling a fuse out? Is there a switch somewhere?
smee
Steamyrotter
Re: is it possible
Post by Steamyrotter » Sun Jul 27, 2014 7:55 pm
When i need to leave the boot open i tend to flip the catch with a screwdriver which turns em off
you need to remember to 'open' the boot before closing though
Please note...
Re: is it possible
Post by X5Sport » Sun Jul 27, 2014 10:07 pm
Does it not turn itself off after a few mins?  ISTR mine did, and the X6 does too.  You may want it to happen quicker though.
Steamyrotter
Re: is it possible
Post by Steamyrotter » Mon Jul 28, 2014 1:20 am
Mine did once... but it was due to battery flattening.....!
Not sure if there is a setting for it.
Will have to have a nose.
Please note...
Smeeagain
Re: is it possible
Post by Smeeagain » Mon Jul 28, 2014 4:21 pm
no it stays on - hence me wanting to switch it off as it just drains the battery if you're doing a job where the tailgate is open for a while
smee
Stevejspm
Contact:
Re: is it possible
Post by Stevejspm » Wed Jul 30, 2014 6:39 pm
Change the filament bulbs for LED's, much less drain on the battery & looks nicer at night!
Smeeagain
Re: is it possible
Post by Smeeagain » Thu Jul 31, 2014 4:50 pm
Perhaps. But the point of the post is that I don't actually want them on ......  :)
Re: is it possible
Post by X5Sport » Thu Jul 31, 2014 5:02 pm
If the car goes to sleep then they should go out, but otherwise you'll have to fit a switch or fool the existing switch into believing the hatch is shut.
TimX5
Re: is it possible
Post by TimX5 » Thu Jul 31, 2014 6:15 pm
[quote="Smeeagain"]
Neither do I , might have to fit a switch.
Steamyrotter
Re: is it possible
Post by Steamyrotter » Thu Jul 31, 2014 9:21 pm
Bugger the switch..
use post 2
the car even comes with the screwdriver to do it...
(cant believe i am suggesting simple solutions... must be ill... or more likely getting old!!!!!)
Please note...
TimX5
Re: is it possible
Post by TimX5 » Thu Jul 31, 2014 9:57 pm
[quote="Steamyrotter"]
Bugger the switch..
use post 2
When I leave the boot lid up with the catch flicked over , our las has a habit of trying to slam it shut  :chop:
